Question about Verbatim SmartDisk Firelite Portable USB 2.0 250GB GO 5400 rpm/tpm 250 GB Hard Drive
I am unable to view the info stored on my smartdisk
    Novelist:
  • 145 Answers
Listen closely for a repetitious clicking. If you hear that you may have a bad disk. If it shows up in my computer but appears empty or unaccessable then you also may have a bad drive. If you can open the drive but nothing it in the folder then the contents may be hidden. If your on windows XP go to tools on the top and then folder options, If your on vista or windows 7 then go to the organize tab and go to folders and search options.From there you will see a folder options window, Go to view and toggle " view hidden files and folders " click apply and ok, and ok to all files and folders. If you see nothing but the computer makes the USB plug in sound you either have incorrect drivers and they need re installation or you disk does not have an assigned letter. Try your disk on another computer in this case. If your unit dos not at all show up or continues to be unresponsive you probably have a bad disk.
Posted on Apr 26, 2010
Verbatim hard drive
Hard drives are fragile, and if they fall sometimes you get lucky and other times no. The only solution is to bring it to a computer store in hopes they can extract your files.
Mar 05, 2012 | Verbatim External, USB 2.0, 500GB...
My SmartDisk FireLite external hard drive is showing 33 GB free out of 55 GB. I had all of my and my wife's files stored on it, but now it only shows all of our folders as shortcuts and says the item the...
I believe some virus caught your computer. If you can't find you're files try this.
-Go to that hard disk.
-In the menu bar look for tools.
-Folder option
-In the folder option window click view
-look for hidden files and folders
-In the 2 radio buttons click show hidden files and folders
-click apply.
If this is correct there is a way to remove those hidden things.
-Select the file or folder you wish to not hide.
-right click and look for properties
-unchecked hidden files and apply
hope this helps. Thank you for using Fixya!
Apr 19, 2011 | SmartDisk FireLite 80 GB Hard Drive
I've had this Optoma PK102 for about year and am not able to get desired results! What cable do I need to connect my Optoma PK102 and Apple ITouch. I have 2 Problems. Problem 1- I am unable to view...
Welcome to Fixya. You need to put the file on the projector for you to view the PPT presentation.
You need to connect a USB cable shown on the image below. If you don't have the cable i suggest you purchase on just bring the projector to a store to have a compatible usb cable.
Use the link below for the manual and more info about the product.
Manual
Specification
Thanks for using Fixya
Mar 13, 2011 | Optoma Office Equipment & Supplies
The 5v power pin on the AC adapter of my SmartDisk Crossfire external hard drive has been broken. How do I get a replacement AC Adapter?
Take your SmartDisk to any computer-store.
They can open the case, remove the disk-drive,
and mount the disk-drive in a new "empty" external casing,
with a new power-supply.
See: http://www.canadaram.com/3_5_sata_enclosures.htm
for a sample of various "empty" cases, for about $30.
Oct 06, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
How can i send pictures from windows photo gallery to verbatim?
When you connect the SmartDisk into the USB port of your computer, the computer will detect this as an external storage device. When you open this SmartDisk you can create folders to store your photos. Just select your photos from your computer where the photos are stored then copy and paste these photos into the folders on the SmastDisk.
Sep 25, 2010 | Verbatim SmartDisk Firelite Portable USB...
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
Unable to access the configuration utility via the web browser I configured the ethernet adapter to be in the same subnet as that of the smartdisk and no luck. device is broadcasting it an address of ...
Have you set each device to different ip adress ???
For access to this function you will have to be logged on to the system as an adminstrator,then you have to test if there is a signal from the path of that ip address,ping the ip address of the device and see how many packets of information are being sent and received
it will give you an answer and confirm if the info has been sent and received
hope this helps
Aug 20, 2009 | SmartDisk Computers & Internet
Smartdisk 80gb has power connection, but data (Mac)
scan the your computer and smartdisk for viruses
the problem you are mentioning about the desktop icons could be due to viruses
also run chkdsk utility on the smart drive after virus scan
Jul 12, 2009 | FireLite (USBFLB80) Hard Drive
ITunes Store .m4v videos do not play on iPod
you should change the .m4v file into mp4 with ipod video converter. ipod only accepts video in .mp4 format.
Aug 03, 2008 | Apple iPod MA446LL/A MP3 Player
Verbatim SmartDisk Firelite Portable USB 2.0 250GB GO 5400 rpm/tpm 250 GB Hard Drive Logo
486 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
