Question about Troy-Bilt Pony Garden Tiller
Disengage wheels from transmission
How do I disengage the wheel locks from the transmission on troy built tiller (tuffy) when it is not running. The wheel locked make it hard to move around the garage. Do not have the manuel
    President:
  • 1,627 Answers
Pull out the bolts that bolt the wheels to the axle,then the wheels will freewheel.
Posted on Apr 26, 2010
How do you get it to free wheel? when you have to move from place to place
That's tricky... some of the small TB will not free wheel and either have to be "drug" from place to place or start up and drive it. Some allow to freewheel by pulling the pins on the wheel hubs, pushing the wheels "in" and reinstalling the pin. This allows the hub to "freewheel" on the axle and the pin just keeps the wheel from falling off. Hope this helps.
Mar 07, 2011 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a troy bilt tiller with a 2hp motor.lately i have had to run it with the choke on and then when i engage the tines it will go dead.have any ideas thanks the engine is a tecumseh
You can check the linkage that links the governor to the carb. If that is fine then you can check the fuel line for a blockage, the carburetor for debris, and if that is fine then you may want to try sanding the rust off the magnet (on the fly-wheel).
May 10, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a Troy Bilt Tuffy Tiller H30-35387S Ser 91330. The only number I can find for the tiller is on the shaft housing between the tines and the wheels and it is X0010527. I need a manual or parts diagram...
You've got the right serial number - it appears you've got one of the older Tuffy's. I'd suggest keeping an eye on Ebay for the manual you're looking for. I find them out there with some regularity. You can't get them from a dealer anymore because this Tuffy was sold by Troy Bilt before they went bankrupt and MTD bought the assets.
Jul 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Free wheel
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Apr 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need manual for a Troy-Bilt Tuffy tiller
Your engine number is wrong by only one character. The proper number is H30-35387S you had a 5 instead of the S. You can download the engine manual from Tecumseh. I don't know about The rest of the tiller. (I have the same tiller).
Feb 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy-Bilt Pony Garden Tiller Logo
411 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
