Question about Ford 8N Tractor
I have a Ford 8n with a new battery, solenoid and starter switch. The tractor was running fine, I shut it off for a few minutes while changing the hydraulic oil and when I turned the key on I had no reading on the amp meter and the solenoid made a clicking noise and would not even trun over. Help!
Clean all the connections where the solenoid bolts to the starter. They are copper. Make them shine.
Posted on Sep 12, 2010
    Problem Solver:
  • 13 Answers
8N's are positive ground negative run...hence the negative wire to the battery. Try jumping the starter solenoid and see if you have a bad solenoid. A second answer could be in your battery. You have a 6 volt battery so be sure to check the charge on the battery.
Posted on May 01, 2010
Wiring a selonoid
http://www.ntractorclub.com/
The link above is just one of a dozen or more very helpful websites for Ford 8n tractors.
The original 8n tractor had a six volt battery with positive ground (this is different than most automobiles that have a negative ground). The starter solenoid is energized via the ignition switch and the large starter button in front of the gear shift, the small wires going to the solenoid energize a coil which "pulls in" and completes a circuit that then provides 6 volts directly to the starter motor through a large, heavy gauge wire. The smaller wires connect to the two terminals on the top of the solenoid and the heavy wire goes to the larger post on the solenoid and originates from the negative post of the battery... Hope this helps. There are many, many schematics and pictures available on the "net" The Ford 8n community is very large and extremely helpful....Good Luck
Apr 11, 2014 | Ford 8N Tractor
My ford 8n starter only clicks, solinoid ok
Are you getting same voltage on each side solinoid when key turned.
Feb 28, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
What would drain a new battery on 2n
I would install a shut-off switch in postive cable of battery
till you the problem.
Jul 27, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
I changed my 1950 ford over to 12 volt and it sat for over 1 year now it wont start so I changed the solinoid ,and ignition switch ,battery,battery terminals and it still wont start and no lights
hey
Recheck the battery connections for crud.Clean battery post/cables and where cables connect to the frame and starter solenoid as sometimes the tractor power feed is at the solenoid.
Good Luck
O if you have a meter or 12volt trouble lamp you can measure across the connection for a voltage drop. With the lights in the on position.
Jan 27, 2011 | Ford Tractor 8n Front Emblem
How does starter drive work
Controlled by Solenoid
  • A car starter is responsible for turning over, or starting, a vehicle engine. Located on the underside of most cars, the starter is controlled by the solenoid, which is a small attachment directly on top of the starter itself or in the engine compartment. The solenoid, which receives electricity from the car battery, is responsible for engaging and disengaging the starter .
  • Dec 28, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
    Do you have starter wiring instructions
    Starter wiring on these are pretty easy, here are the following steps...
    First, disconnect the battery first before attempting any wiring repair or replacement of electrical system components. I assume the old starter has been removed, so here are the steps to wiring on the new one.
    First trace the generator wire (generally a 10 or 12 guage) wire from the generator. this wire along with your positive terminal cable from the battery and a wire which runs to the "light" pull switch all connect to the left side of the starter solenoid which i on top of the starter housing. This solenoid has "2" sides. With the bracket at the rear (towards passenger seat) the left side holds the three wires discussed above. The other side should be connected to the starter itself that has a bolt on the outside. This is a ground wire. If your starter didn't come with a new start solenoid, then this ground wire from the starter will go on the right side of the solenoid. Lastly, there will be a place to mount another wire to the top of the solenoid housing. This wire will run to the push button start near the gear shift on transmission housing. After all these connection have been completed, then reattach wires to the battery, and the tractor should start. If the tractor has been stored a while, may want to drain gas and replace with new for best start, and also check all the fluids such as water, oil, and the trans/pto/and hydraulic lift fluids.
    Let me know if you need anything else!
    Chip
    Apr 03, 2010 | Ford 8N Tractor
    My ford 8n starter just clicks now. Is there anyway to get this to stop and work corectly?
    You likely need to replace the starter solenoid switch,if it just clicks then one of the contacts has worn out.If the starter is a delco,order one for a Chev half ton 1980, and it will be about $30 cheaper and do the same job.
    Feb 15, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
    Ford 8n won't crank
    Hi..my name is Keith..and the 1st things that i would check is to make sure the battery terminals and cables ends are clean..if they are..i would check to make sure the ground wire and where it connects to the frame is clean and rust free..and if they are in great condition....i would suspect the starter solenoid..i'd make sure all the connections are clean on it..and if it still dont work after you cleaned it...i would replace the solenoid..i hope this helps..and there could be other things..so if it dont solve your problem..write me back
    Jun 22, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
    1950 8N FORD TRACTOR WON"T START.
    Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
    Apr 13, 2009 | Ford Tractor 8n Front Emblem
    Starter on ford 8n tractor will not engage.
    Did you check for voltage at the starter connection at the starter connection AFTER the solenoid.......when the solenoid is energized?
    Just because it clicks does not mean it is sending power through.
    Does the starter have a good clean ground?
    Use a battery booster cable and supply your own battery power right to the starter to check it.Try grounding it too with the other battery booster cable.The starter drive is only used when the starter is turning as it is thrown out into the teeth of the flywheel...cranking the engine and back out away from the flywheel when the starter stops turning.
    Apr 05, 2009 | Ford 8N Tractor
    Ford 8N Tractor Logo
    1,390 people viewed this question
    Top Ford Toys Experts
    D. E. Hev
    Are you a Ford Toy Expert? Answer questions, earn points and help others
