Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
No pressure getting through to gauges
Electric motor starts okay but no build up of pressure to the gauges.
    Problem Solver:
  • 12 Answers
Remove the intake filter and check to see if the compressor is sucking or blowing if it is blowing out air from the intake you have a bad valve
Posted on Apr 29, 2010
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
My low oil light comes on while trying to crank my car and car stalls; will not start until I keep trying a couple of times. After it starts it runs fine and then shuts off after backfiring sometimes and...
LOW OIL PRESSURE WILL CAUSE OIL PRESSURE SWITCH OR SENDING UNIT TO DISABLE FUEL PUMP.CHECK FOR OIL PRESSURE.REMOVE OIL PRESSURE SENDING UNIT SCREW IN OIL PRESSURE GAUGE TESTER INTO BLOCK WHERE OIL PRESSURE SENDING UNIT GOES TURN ENGINE OVER CHECK FOR OIL PRESSURE SHOULD BE 18 PSI @ 2000 RPM. BESURE TO WRAP TEFLON PLUMBERS TAPE AROUND THREADS TO THE OIL GAUGE PRESSURE TESTER OIL WILL SPRAY EVERY WHERE.IF YOU ARE GETTING NO OIL PRESSURE.YOUR OIL PUMP FAULTY.YOUR ENGINE CRANKSHAFT BEARINGS WORN OUT.WORN DAMAGED CAMSHAFT OIL PUMP DRIVE GEAR OR OIL PUMP DRIVE ROD DAMAGED OR BROKEN. IF OIL PRESSURE OKAY OIL PRESSURE SENDING UNIT IS BAD.
Sep 28, 2011 | 1994 Chevrolet Caprice Classic
Sears/Craftsman air comp./paint sprayer mod# 106.154881 3 hp 30 gal. starts fine - pressure builds to 20# then motor boggs down then restarts over and over.
Your wire to the motor is too light a gauge wire or you are using too small of a gauge electric cord on it.
For a three HP motor you will need to use at least a 10 gauge wire or cord on a thirty amp. circuit...
heatman101
Feb 22, 2011 | Craftsman Air Tools & Compressors
Car wont run or start motor okay starter okay gauges okay battery okay fuses okay maybe key switch maybe something else
F >> Fuel
A >> Air
S >> Spark
T >> Timing
Have you checked to see if you're getting fuel? Bad injector
Bad Coil Pack(s)?
Are you getting a spark from your spark plugs?
Checked vacuum hoses?
Hope this helps
Oct 21, 2010 | 2001 Buick Century
I own a GBG power 2000 pressure washer and I cannot get it to run. It will hum for 3 seconds and then trip the reset.
Release the trigger pressure to allow for start up. Sounds like motor jambed by pressure build up. After motor is running it should be okay.
Oct 06, 2010 | Garden
Don't continue starting
When a car runs for awhile but then stops, one considers things like fuel filter, vacuum building up in the gas tank, etc.
The best way to tell is with a fuel pressure gauge attached to its port.
If the pressure drops, it could be a clogged filter.
but also remove the gas cap and listen for a hiss.
Feb 28, 2010 | Hyundai Motor 1998 Sonata
Will not build up pressure
You did not state whether the compressor would kick on automatically, or whether it would kick off at some point, so I have to work through it with you....
If the compressor runs, you should see pressure on one of the two gauges. The gauge that is closest to the tank is the pressure that the compressor proper is putting out to the tank, and is the primary gauge. The other gauge is the pressure supplied to the tool via the hose, downstream of the regulator. If you are seeing pressure at the first gauge, that's a good sign. Also a good sign is if the commpressor runs and switches off at some point before lifting the PRD (pressure relief device). This tells you that the compressor is pumping and that the pressure switch is working. If this is the case, try working the regulator control knob and watch the second gauge. The regulators can be tricky; sometimes the regulator knob operates in the opposite direction than expected, depending on the type of regulator, so experiment a bit. (Usually there is wording and an arrow on the knob telling you the direction to adjust. If you start to see a rise in the pressure on the gauge, go ahead and set the desired tool supply pressure.
If you can get a pressure on the first gauge, but nothing on the second gauge no matter how you manipulated the regulator, you should suspect a bad regulator.
If there is no pressure on the first gauge, try cracking open the drain valve on the tank and starting the compressor. If you get air out of the tank with no indication on the gauge, you should suspect a bad primary gauge. If you get no air out of the tank, open the drain valve further and check again. If still no air, the compressor itself is suspect. You will need to determine that the motor is in fact turning the compressor. If the motor is running, but the compressor isn't moving, unplug the compressor and reconnect the linkage. If the compressor will run with the motor, the compressor may be shot, or tha air intake may be plugged off. Remove the cover on the air intake and inspect the filter. Clean and replace as required.
If the compressor will start when you operate the on/off switch, but does not kick off at some point, the pressure switch is probably at fault. It is an odd piece of work....it is mechanical, electrical and pneumatic, all at once. You would need to troubleshoot each portion in order to put it right. The most common problem with the pressure switch is burned or welded contacts, followed by wiring issues to the contacts, then the air line to the switch, then mechanical linkages within the switch.
This humble guide should be enough to get you going. I hope that it has been useful.
Regards, and good luck!
--W/D--
Jul 18, 2009 | Campbell Hausfeld 02-Gallon Air...
EC-12 runs but only builds to 35 psi and continues to run
It looks like there might be a knob which sets the max air pressure coming from the compressor. If there is one, this may have been turned down.
There are usually 3 pressure settings on an electric compressor. Compressor max, pressure switch cut on, and pressure switch cut off.
Apr 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
185 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
