Question about Nikon Coolpix S510 Digital Camera
Lens Cover Error
When I try to turn my camera on.. I get the error message:
Lens Cover Erro
The shutter is not opening... anything I can do to fix this problem?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 13, 2011
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
My Nikon D3200 says shutter error can I fix this issue myself?
hi,
did you charge your battery full ? if the battery is not charged enough, it will not drive the shutter opener motor perfectly, and if any type of dirt or friction on the shutter drive gears this will happen, please check the shutter movement by removing the lens.
Feb 23, 2015 | Nikon D Cameras
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
The camera screen stays black, and I can not see anything through viewfinder or on the screen. When I take pictures, they are completely black. Is the camera worthless now?
It sounds like the CCD has gone bad, in which case, the camera is not getting repaired, since it sits on the main circuit board, and you would have to buy the entire board, plus pay the extensive labor. There may be a chance that the shutter is stuck closed, and you might try some suggestions I ran across on a web blog. The blog deals with error messages and lens assembly problems, so it's worth trying:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Hope this helps.
Jul 07, 2010 | Canon PowerShot S3 IS Digital Camera
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Error message 5555AAAA-4489-163-062
check if the little metal lens cover is stuck open.  Mine was stuck open, so I just smacked the camera against my hand and the cover popped closed.  Then the camera turned on normally...
Oct 24, 2007 | HP Photosmart R725 Digital Camera
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Nikon Coolpix S510 Digital Camera Logo
56 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
