Question about Radio Communications
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
    Genius:
  • 1,274 Answers
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Posted on Apr 28, 2010
Cobra 29 now Ltd classic Cobra 29 nw.ltd classic receives not well but does not transmit don't even move the swr./power meter any ideas
High SWR on antenna system.. may have mess up your RF final transistors. if you were talking on it for a long time. have someone check the SWR on the antenna system... should be a FREE service.
Jul 13, 2014 | Radio Communications
How do you set the SWR on a cobra 29 LTD classic radio
the same way you set it on any other radio.Look at the face of the set,you will see a switch that says S/RF,CAL , SWR. Now look at your meter and you will see a triangle that shows cal.Put your set on ch 1 with the switch in the cal position and bring the needle to that calibrate line on the meter by keying the mic. now release the key and set switch to SWR and key the mic again.Now write this reading down.Repeat for channels 40 and 19. If the reading is higher on 40 than on 1 you need to shorten the ANTENNA.If its higher on 1 than 40 you need to make your ANTENNA longer Always check 19 to make sure you have an average SWR. Any reading under 1.9:1 is good
Jun 15, 2014 | Cobra 29 LTD CB Radio
I have a Cobra CB Radio and was wondering if I have it on SRF or SWR or CAL
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjust-
ing the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
You will want to operate on S/RF position.
Jul 14, 2011 | Cobra 29 LTD CB Radio
Swr meter not moving
follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
Jan 14, 2011 | Cobra 29 LTD CB Radio
I want to calibrate my cobra 29 NW Ltd. Classic
Calibrate For SWR (Standing Wave Ratio) http://www.cbtricks.com/radios/cobra/29ltd_bt/graphics/cobra_29ltd_bt_om.pdf
The CAL is only to calibrate meter for a swr check of you antenna system it does not calibrate radio.
Jan 11, 2011 | Cobra 29 LTD CB Radio
I have a cobra 29 wx nw st withwilson little wil entenna. I am having issues with a no swr reading on channel one even if I turn my swr cal all the way up. My 40 cal reads on the swr at .5 no matter how...
first of all you are going about it wrong. To set your SWR you check it on channels 1 , 19 , and 40. If you reading is higher on 1 than on 40 you have to shorten your antenna . if its higher on 40 than on 1 then you have to lengthen it. before you do any adjustments to it ,loosen the set screws and let the antenna fall to the bottom then bring it up 1/4 " and tighten the screws. You should also use an external SWR meter not the one on the radio. Thats good for making checks every once and a while. With the meter you key the mic and have the needle go to set then put it on for and key the mic to obtain you reading . Anything under a two is good .
Dec 16, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Dont know how to use the swr meter on my radio
With radio turned on
1. Switch the first switch (S/RF SWR CAL) to CAL setting
2. Key mic up &
3. Turn SWR CAL knob while still keying mic until the needle is on the red CAL arrow at the far end of the meter scale. Unkey mic.
4. Switch the first switch back to SWR setting.
5. Key mic up again and record SWR reading and adjust as needed.
6. When done adjusting put switch back in the S/RF setting for normal operation.
Do not flip the switch with the mic keyed up.
Jan 19, 2010 | Cobra 29 LTD CB Radio
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
SWR meter will not go to cal line.
vr2 is the transmitt signal potentiometer for the meter adjustment during keyup try turning it while keying but use something nonconductive to do so or you could short it..be carefull
Jan 24, 2009 | Cobra 29 LTD CB Radio
My Meter Won't Move
weather can effect your meter .Those meters are not very accurate just a base line get a good swr meter and then check it.If your getting good radio checks it could be the potentoimeter is dirty . Radio shack sells contact cleaner and lube try cleaning it . That might help
Jan 08, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
102 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
