Question about Frigidaire ATF6000ES Front Load Washer
The drum of my washer doesn't turn during the spin nor the wash? Should I repair it or buy a new one??
  • 401 Answers
CAN YOU TURN IT BY HAND? IF SO IS ALL THE WATER OUT? CHECK THE BELT AND MAKE SURE THE PUMP IS NOT LOCKED OR BLOCKED
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Apr 26, 2010
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
Smokes on final spin
door gasket. pain to replace. clean stainless steel drum where it contacts rubber before installing a new one. I used baby oil and very fine steel wool.
Dec 12, 2011 | General Electric WCVH6800J Front Load...
I have a GE front-loading washer. There is a horrible thumping noise as the drum turns. It is not constant - when I turn it by hand it seems to "thump" on every rotation of the drum. I ran it...
The thumping sound is a sure sign that the spider arms or the support arms that hold the wash drum are broken. It is a very expensive repair since you need to buy a replacement wash drum and spider arm assembly which almost cost as much as new washer. Get a few estimates before deciding whether to repair or replace the washer. Sorry.
Apr 23, 2011 | GE WSXH208A Front Load Washer
My whirlpool duet washer make a loud banging sound during spin - louder when it goes into super spin
It sounds like the spider or support arms that hold the wash drum have failed and the drum is hitting the wash tub when it is spinning. Try spinning the inner drum by hand and listen for any thumping sounds as it turns. Also examine how it turns, if you notice that is wobbles as it turns, it also means that the supports are failing.
It can be fixed but it might be expensive. Get a few estimates before deciding to repair or replace. Hope this helps you.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The drum fell out of the socket and unable to spin at super fast speed, so the extract cycle/final spin does not fully extract the water. is it worth getting this fixed or should i just buy a new washer?
If you turn the inner drum by hand and if you hear thumping noises as it turns or it does not turn smoothly. The problem is probally a broken spider or support arms. It is very expensive to repair, costing as much as a new washer.
Jul 29, 2010 | Frigidaire ATF6000ES Front Load Washer
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
172 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
