Question about RCA F36669 36" TV
No life I was quietly watching tv (with a satellite connection) and the screen went black and lost sound. If I turn it off then back on the channel number comes up. If I search the cable listing I can see those, but that's it.
  • 149 Answers
Sounds like the sat receiver not the tv.
Posted on Mar 23, 2008
Screen went black while watching, now ony have sound
Look at the venting grills, you should see whit lights inside the set. If not, the backlight inverter board may have gone out or the power supply supplying the power to the inverter board may have gone out. Those are the two places to look first. It may have bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
My flat screen lg tv has lost its channels,says its not programed...help
i was watching tv last night on my lg,and it went off and said no signal?so i went to retune and now it says not programmed i cant get my dtv channels back
Aug 20, 2009 | LG 42PG20 42 in. Plasma HDTV
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Black Screen
The first step here is to isolate the problem. You need to know if it is in your TV or DVR. Unplug your TV from the DVR and connect it directly to the wall outlet. Then connect a TV antenna, or a small thin wire, to the F connector on the back of the TV (this is the threaded connector - where you plug your cable). Try searching for some air channels and see if you get any channels at all, and post back.
Feb 26, 2008 | Apex Digital AT2708 27" TV
Blank tv screen when turned on
the problem is in your tuner section or video if section check for its proper voltage. if you are not tech. person get the help of tech person it is not a major problem.
Oct 01, 2007 | Philips Magnavox 20MT4405 20" TV
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
RCA F36669 36" TV Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
