Question about Minn Kota Maxxum Pro 80 Freshwater Transom Mount Trolling Motor With 42" Shaft
Replacing streering cable
Instructions on replacing the steering cable on an Minnkota Maxuum pro trolling motor
5 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Posted on Oct 20, 2008
Editor925
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
Posted on Apr 30, 2009
SOURCE: m y minn kota trolling motor cover busted
HOPE THIS HELPS
Posted on Jul 14, 2009
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
Oct 03, 2016 | Humminbird Boating
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    I have a 65 pound thrust all terrain MinnKota trolling motorThat stopped working on me the other day when I was fishin.Iwas fishing and was trolled 2 another spot when I got there I stop the trolling...
    Hello John,
    Most Of The Time I Find The Problem Is With The Cables And Connections To The Battery?
    Remove Battery Lugs And Cables Clean All Contact Areas .
    Re Connect And Test Again
    Hope This Helps
    Gordy
    Dec 01, 2017 | Boating
    Looking for parts brakesdown minnkota 101
    Google the Make and model...dozens of web sites, including MinnKota,
    Dec 16, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Lcx26hd screen gets black when minnkota trolling motor is on has got good picture when off
    Sounds like a simple voltage problem due to the current draw from the trolling motor. You will need to have a seperate isolated battery to run the trolling motor.
    Sep 15, 2009 | Boating
    Minn Kota Maxxum Pro 80 Freshwater Transom Mount Trolling Motor With 42" Shaft Logo
    180 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
