Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Scanner I have an HP Photosmart 2575 All- in-one and cannot scan. I took it to a computer expert who re-installed it for me and had it scanning but won't scan at all for me. it comes up on the small screen: No scan options. Refer to device ducumentation to troubleshoot. Press ok to continue. I have checked the connections and they seem to be ok. I really need your help a.s.a.p. Thankyou.
  • 2 more comments
  • chasat54 Jun 15, 2008
    Hi, my problem is HP Photosmart 2575 all in one will not scan, message , please help.
    chaon small screen- troubleshoot problem in documentation.When Itry to scan through HP Solution Centre message reads- (An error occurred commmunicating with the device. Please ensure that the scanning device is connected properly and try again.) .Tried scanning using the wizard, and it works, also prints ok. I also ran Diagnostic test, found 2 problems, which have been fixed, followed all instructions given from HP. PROBLEM still theresat54
  • Anonymous Aug 30, 2008
    I have an HP HP Photosmart 2575 All-In-One Printer, Scanner, Copier.  When I try to scan it says "No Scan Options" even though I'm connected via USB. Please help.  Thanks.
  • nicolahathaw Aug 31, 2008
    No scan options.
    Thankyou.
  • Anonymous Sep 26, 2008
    cannot scan . my printer caused mr problems when i changed my computer from windows to windows vista. contacted hp who download an
    updated program . since then i have no scan option.
I have the same problem please help...
Posted on Sep 21, 2008
    Genius:
  • 3,587 Answers
Ok..
check usb connections first
restart scanner
remove old s/w
go here for new drivers for that HP
if all else fails, send me an email through my profile information
Posted on Mar 23, 2008
We have( several years now) a HP photosmart 2575 All-in-One , we need to scan documents, it was never set up to do that ,we have misplaced the manual as to set it up to our computer. can you help
1) Make sure that you have the HP driver and full-software installed. Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=441240& , select your OS and click Next. Then click on Driver to download it. If you installed the generic driver from the OS, uninstall it and unplug the data cable (if USB) before installing. For some of OS versions, even if you do have the full software, check the version you have, some need to be patched. All of the support for this all-in-one is available here: http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=&cc=us&product=441240 .
2) Place the document to scan face down on the glass or face up in a Automatic Document Feeder (ADF).
Next you can scan from the computer before you can scan using the buttons on the printer. If you want to use the scan buttons, you will need the full software installed and the monitor program running. Then you need to set the button destinations in the HP Solution Center before the buttons will work. Launch the HP software (Start > All Programs > HP > HP Solution Center (some HP printers have a slightly different program but it will be in the same HP folder). Launch the scan and set the resolution and destination folders. Windows computers can also scan from the computer with Paint (File > Import from Scanner or Camera) or Windows Fax and Scan (Vista and Win7).
If you have problems, check the USB cable first. Scanners require bi-directional communication with the computer. Thus they fail when the printer works. Make sure that the scanner is unlocked if a lock exists.
I hope this helps.
Oct 08, 2010 | HP Photosmart 2575 All-In-One Printer,...
I have an HP Photosmart 2575 All-In_One Printer, Scanner, Copier, but when I try to scan a document it says No Scan Options and below that refer to device documentation to troubleshoot. I have no...
if it is XP, then click on start , then run , in run type wiaacmgr.exe and hit enter, try to scan.
In vista and windows 7 , replace run with start search box.
Apr 09, 2010 | HP Photosmart 2575 All-In-One Printer,...
HP Scanner will not scan??
Sounds like a driver problem.
I would uninstall the drivers and reinstall them. Be sure to keep the scanner disconnected from the computer until the software prompts you to plug it in.
Afterwards I would go to the HP site and download the updated drivers.
Sep 26, 2009 | HP Photosmart 2575 All-In-One InkJet...
Photosmart 2575 all in one printer- says "no scanning options "
you didn't instal the printer in you're pc. try to install the printer /scanner driver
Jun 17, 2009 | HP Photosmart 2575 All-In-One Printer,...
I have a HP 2575 photosmart 2575 All in one series
Are able to print? If yes, please tryy to scan by using Ms Paint. If you can scan from Ms Paint please reinstall the scanning driver software. You can download the full feature drivers and softwares from www.hp.com.
Mar 18, 2009 | HP Photosmart 2575 All-In-One InkJet...
No scan option
uninstall printer software and then reinstall from cd that came with it if you have it if not you can download from hp solution center.
Dec 29, 2008 | HP Photosmart 2575 All-In-One Printer,...
Scanning
My Photosmart 2575 v has worked fine as well for over a year and now it won't scan. I get the same message: "Refer to device documentation to troubleshoot". I ran all updates and they said I have them all and everything is working perfectly. It's not though. I still can't scan. I tried their work-around by opening paint and then acquring image from the scanner but that does not work either.
Apr 30, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 scanner / copier
The most common causes of this issue are 1: you do not have the software installed on your computer (or you need an updated version form the HP web-site) and/or 2: you are connecting to the printer over a network and your firewall is stopping the printer from accessing the HP software on your computer. A little more info would be helpful in diagnosing the problem; What Operating System is your computer running? Is your computer connected to the printer via USB or over a network? Do you have the latest HP software installed? Do you have more than one printer, scanner or all in one device connected to your computer? Has the printer always had this problem or has it worked before?
Aug 16, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
132 people viewed this question
Ben Johnson
