Question about Sony KV-35V36 35" TV
I have sound but no picture
I have sound but no picture on my Sony Trinitron TV KV 35v36
  • 308 Answers
SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Posted on Dec 24, 2006
jerryg50
  • 1667 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Posted on Jul 12, 2008
ikecur
  • 52 Answers
SOURCE: Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Posted on Oct 30, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
Posted on May 19, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
How can i get picture and sound? the tv is sony trinitron kv-35v36
you need to check for an open resistance at the crt board or a bad potentiometer for screen control.
Feb 12, 2013 | Televison & Video
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have a Sony KV-35V36 TV. Will watching TV and the power just went off. We get no power all all anymore. How do you ge the the fuse on this TV.
The fuse is inside the chassis and likely soldered. Unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if that has reset it.
Is the outlet good, or did the power outage trip the breaker?
Apr 22, 2011 | Sony KV-35V36 35" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cant get the cable picture dont know what happened to the cable behind the tv but no picture or sound is present.
Check the F-connector. Unscrew cable from set make sure F-connector has not slid forward on cable and that copper center wire extends out.
Jul 08, 2009 | Sony KV-35V36 35" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
FV-27KV300 WEGA 27" Sound Problem
adjust the sound IF in the tuner or in the IFblock
May 03, 2008 | Sony FD Trinitron WEGA KV-27FV300 27" TV
Sony 35inch Trinitron Color TV
Hi. I dont recognise that model number. Take a look at the rear of set & see if there is a chassis number eg AE1. AE1A, AE1B, AE1C, AE2, AE2A, AE5, AE3B, BE2, BE2A,BE3, DE1, F1, FX, These are some of the common older chassis. You say led flashes does it flash 2, 3, 4, 5, times etc then pause then repeat ?
Sep 23, 2007 | Sony KV-35V36 35" TV
Televison & Video Logo
169 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
