Question about Kitchen Ranges
NEED CLEANING INSTRUCTIONS FOR A kENMORE RANGE
  • Kitchen Ranges Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 26, 2010
2 Suggested Answers
  • 1214 Answers
SOURCE: need manual for Kenmore Range
You can download one for free at www.managemyhome.com
Posted on Jan 30, 2009
I have a Kenmore electric range. Self-cleaning. Model# 911.9349181 How do I work it?
This link downloads a PDF that may provide a solution for your issue, as it says "This Use & Care Guide contains operating instructions for your appliance and feature information for several models .... ).":
Kenmore® Electric Range c.shld.net/assets/docs/spin_prod_892089512.pdf
Aug 17, 2016 | Kenmore Kitchen Ranges
Looking for instructions on how to replace the main cooktop on our kenmore elite elecric range, model 790
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
Aug 03, 2016 | Kenmore Kitchen Ranges
I need a manual kenmore slide in range electric 90152
I don't believe that is the actual model #. Pull out the drawer and look for a sticker on the frame of the stove. Also open the oven door and look for a sticker on the frame there. If its a Kenmore the sticker should have something similar to "970-", "956-", "110.", "646-". Take the full model number and Google it. If its a "970-" you should be able to find the manual here: http://b2b.frigidaire.com/support/manuals.asp
Apr 12, 2014 | Kenmore 90154 / 90152 Electric Kitchen...
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
No instructions for self cleaning oven
I turned both dials to clean and worked with the start timer and the stop timer until it engaged. I now have a clean oven again!
Feb 06, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Need manual for Kenmore Range
Jan 30, 2009 | Kitchen Ranges
How do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Dec 27, 2008 | Kenmore 75503 Stainless Steel Dual Fuel...
Self cleaning oven instructions
you can google it or just push the clean button and it will most likely default to 3 hours and all you have to do is push start and after it is done wipe out the ashes with warm soapy water DO NOT USE OVEN CLEANER as this will destroy the finish of the self clean cavity
Nov 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
