Question about Nikon D70s Digital Camera
Nikon d 80 flash will not pop up while in auto mode
The flash will not pop up when I take pictures. The flash will fire because you can hear it. I manually have to pry open the flash.
I'm going through the exact same problem.
Posted on Apr 20, 2013
    Scholar:
  • 85 Answers
Put it in Auto (Green) mode then try, if flash pops up, it is the case of settings otherwise mechanical problem.
Posted on Mar 27, 2008
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Flash does not work
Nikon has several modes for flash. When you are in Full Auto then auto controls the flash. When you are in P mode then you determine if the flash should fire. The flash menu allows you to ALWAYS fire. NEVER FIRE and some other, Like RED-EYE modes. So put the camera in P and go to Flash menu and make sure it is ON.
Oct 23, 2013 | Nikon Inc Nikon Coolpix L610 Black
I have a Nikon D40X. The built in flash pops up but the flash does not go off (light up)....not aware of the capability of turning it off manually.
You have 2 options to try before you consider a service tech to look @ the camera.
Prelim : Ensure the batteries are charged & your using standard batteries.
Option 1 : Put the dial in Auto mode and see if that helps with the flash, also ensure you are trying to click the picture in a dim or dark environment, else the Auto flash won't fire if the environment is bright enough
Option 2 : Backup your pictures and reset your camera by using the menu. This should take care of any settings that might have been accidentally turned ON or OFF, then try to get back to the option 1 to see if the flash fires... (you will have to set the date & time post this action)
Mar 30, 2011 | Nikon D40x Digital Camera
No camera flash
If the pictures are good, don't worry. The auto-mode will pop the flash when needed.
If the pictures are not good, check the flash mode and set it either auto or on or fill-in.
Dec 13, 2009 | Nikon COOLPIX S60 Digital Camera
I can't seem to turn the flash on my Nikon D70 on! I've been playing around with it for hours and have read through the manual. I've followed the steps clearly, but nothing is working. The previous...
If nothing else it should pop up when you put the camera in A or M or S and then press the flash button on the side. It might or might not fire, depending on the light available, but it should for certain pop up. When you do this, you should hear a click and the flash should pop up. If you hear the click and it doesn't pop up, then it's jammed or glued or somehow being mechanically prevented from coming up.
In Auto modes, you can select the flash to off with the side button and the back rotary selector. This is where the flash symbol with the slash through it tells you the flash is off. If you push the flash button in Auto modes with the flash selected off, it won't pop up.
There are also some things the D70 can do to control external flash units that may be set abnormally.
The best way to make sure those aren't messing you up is to select "reset to default". That will take the camera back to a base setup that should work.
If none of these things gets it going, take it in to the Nikon dealer in town.
Sep 01, 2009 | Nikon D70s Digital Camera
I HAVE A NIKON D40X.I CANNOT GET THE BUILT IN FLASH TO WORK.IT IS IN AUTO MODE AND FLASH IS TURNED ON.IF I ATATCH AN EXTERIA FLASH IT FIRES EVERY TIME.I HAVE TRIED IT ON ALL THE OTHER MODES,IT DID FIRE...
In Auto mode the flash will only fire when the camera thinks it needs it.
Only in the PASM modes do you get to decide whether to use the flash or not.
Aug 27, 2008 | Nikon Cameras
The flash up button is located on the left hand side of the camera right near the top.   You should use this button to pop up the flash. Prying it up could/has broken this button.
Also, depending on what setting you are using, the flash doesn't always pop up automatically.   Check to see what mode you are in, on the round dial on the left -- ie  Auto, Portrait, Manual, etc.   I can move sometimes without your knowledge, and this may be the problem.
Apr 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
AF area mode problem
To answer your flash question...the Nikon flash system fires the flash when the camera thinks the picture will be too contrasty without the flash. You can Google for "fill flash" to learn more. This is usually beneficial; if not, holding the flash button and turning the main dial will cycle through flash options on the top screen.
Jul 17, 2007 | Nikon D50 Digital Camera
Nikon D70s Digital Camera Logo
263 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
