Question about LG 47LG50 47 in. LCD HDTV
Hi, I just got an LG 47LG50 flat screen from a friend, the glass screen behind the plastic covering is cracked, i was wondering what the protocol was for replacing it and if it would be very expensive?It is for sure cracked beyond any repair, thanks be to Nintendo and the Wii-mote. Thanks in advance for the help anyone.
  • ragnarok993 Apr 26, 2010
    I know it is expensive to get it fixed, i was wondering more about how much the replacement screen was. I have some experience in tv repair, i just want to know if it is possible to replace it and how much a replacement screen MAY cost.
  • 80 Answers
Too expensive.
Posted on Apr 26, 2010
  • Martin Smith Apr 26, 2010
    about four hundred dollars doing it yourself.
How do I fix the LG 47LG50 which powers on but only has a dim blue glow on the screen?
Sounds like display panel fault. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 21, 2015 | LG 47LG50 47LG50 47-inch 1080p LCD HDTV...
How do I fix an LG 47LG50 Television which powers on but has only a dim blue screen and no sound?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
How to crack the system password for LG LED TV 42LS4600
There is no such procedure to crack the password. If you've forgot the password, contact the authorised service center to LG.
Sep 18, 2013 | LG 47LG50 47 in. LCD HDTV
Is their anyway you could fix a 47LGLM6700
Unfortunately no, you would need to replace the internal panel on the TV and honestly the labor and part would cost more then just buying a new set in most cases. If the screen has a glass cover and just the glass is cracked but the rest of the picture looks fine (no distortion in the LCD) then you could just remove the glass and run the screen unprotected or copy the dimensions of the glass/plastic and send it away to have a new sheet made to fit.
Apr 07, 2013 | LG 47LM6700
Hi i have an lg 37lc7d-ub but my screen just cracked i am trying to find a way to replace it and about an estimate i dont if you guys may help me??
Sorry Joshua.... there is no easy replacement option and you are better off just replacing the set than trying to have it fixed- chances are it will never be the same even if you could find a replacement screen (I have my doubts that they are even available), and the "fix" will most likely exceed the cost of a new set. I have not cracked open an HDTV case yet to see for myself (and probably never will), but my understanding is that there are several thousand connections bonded between the rear of the screen and the control board, which lies up against it, and the bonding is performed in a clean room environment.
Sorry.
Jan 28, 2011 | LG 47LG50 47 in. LCD HDTV
How do I remove the bezel from my hp l1955 monitor
There usually screws hidden behind stick-on plastic covers on the front and or edges of the screen. Use a sharp point to lift off these covers to reveal the screws.
The bezel will also have plastic catches/clips that secures the bezel to the lid as well as double sided tape. Slip a thin blade between the glass screen and bezel and gently lift the bezel free. Start at a corner and gradually work along each side.
Be careful not the apply too much pressure on the glass (it is easily cracked) and be careful not to scratch the screen.
Nov 15, 2009 | HP L1955 19" LCD Monitor
Need to replace the screen of the seedometer CL216
well ,the best thing I would do is search out a salvage yard and see if they have the part in question .
Then the dash covering will have to be taken off the panel of glass/plastic should be resting right behind the dash console.
Feb 21, 2009 | 2008 Mercedes-Benz Mercedes Benz Cl Class
Cracked While Cleaning
I did that to a Toshiba laptop long ago, happens to the best of us. I think they?re referring to the LCD panel itself not a piece of glass you can replace. Usually the outer layer you can touch is a plastic/vinyl layer that covers the outer glass layer. Behind that is another sheet of glass and sandwiched in-between is the liquid crystal material. All of this is bound together as one unit and not repairable.
Dec 31, 2006 | LG L1915S 19" LCD Monitor
LG 47LG50 47 in. LCD HDTV Logo
307 people viewed this question
Computer Repairing
Computer Repairing
