Im afer a manual for a yunca leedz 1 gas fire
1994 sentra will crank, but has trouble firing unless im pressing the gas.
Sounds like the fuel pump is failing, have the pressure checked at start up.
Apr 04, 2017 | 1994 Nissan Sentra 4-Door
Im working on a ford ranger 2002 with the v6. i just need to see a pic of the piston order and the coil pack order. im getting codes for 4..5..6 missfire but im not sure witch ones they are
Cylinders 1,2 and 3 are the cylinders on the passenger side and cylinders 4,5 and 6 are the cylinders on the driver's side. They are numbered front to rear. The coil pack will have the cylinder numbers marked on the top of it. The actual firing order is 1-4-2-5-3-6
The top of your coil should look like this:
1 2 3
5 6 4
Your engine looks like this:
1 2 3
FRONT OF ENGINE
4 5 6
Apr 15, 2011 | 2002 Ford Ranger Regular Cab
What is the firing order afer you replace the timing chane in the yamaha motor cycle
I think you are confusing firing order with camshaft timing, you may need to repost the question asking for cam timing position for your particular model
Mar 05, 2011 | Yamaha TT-R 225 Motorcycles
Im 250 nailer wont fire new gas , all good battery charged cant seem to see spark what next
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
-]0]0-
Oct 21, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Message center says "Fuel Computer Failure", gas gauge drops from 1/4 to empty - car runs out of gas. Fill tank with gas and car runs fine. 2005 LIncoln LS V8.
hi,
Im looking online and its looking like the sending unit in the gas tank, this tells the computer how much fuel is in the tank. its in the gas tank with the fuel pump. the gas tank has to come out and its a pretty straightforward easy weekend job. get yourself a haynes or chilton manual for the lincoln at the auto parts store. run it out of fuel again and follow the procedure for tank removal in the book or google it. spray the gas tank strap bolts with wd-40 too. have a garden hose and fire extinguisher handy .
good luck
jm
Aug 19, 2010 | 2005 Lincoln LS
I dont' think it is drying my clothes. It's not getting hot?
gas or electric? if electric then probably either plugged exhaust hose or bad element....if gas then probably either plugged exhaust hose or temperature shut off switch or 1 0r both magnets on the gas valve,listen for the burners to ignite,if the burner shuts off afer 1 minute of running then double check the exhaust hose,the burner should run lots longer if working right.
Sep 10, 2009 | Maytag Dryers
Dryer will fire up and then shud down
You may need a motor .It sounds like you have a weak motor.When you start the dryer does it make a humming sound or sound slugish?Motor problemGoog luck:)
May 07, 2009 | Dryers
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Mar 08, 2009 | Heating & Cooling
Injectors not spraying
I'm not a pro but sounds like your injectors might be clogged. Try buying a high strength fuel system cleaner from like Autozone but sounds like you might have to remove the injectors and clean them manually. Are you sure they are firing? You can listen to them fire by placing a stethoscope on them and verify there is a uniform ticking noise in them while the engine is running.
Jul 31, 2008 | 1992 Geo Storm
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
