Question about Haier HLP140E Electric Portable Dryer
I need an exhaust filter for my Avanti dryer. model # d110
Electric cord overheated, blew fuse, need replacement
Contact Avanti Customer Service, or search for a replacement using eBay or Amazon.
May 11, 2015 | Avanti D110 Electric Portable Dryer
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Dryer runs for three or four minutes then shuts of and willnot start for 10 minutes or longer'
Could be motor overheating and shutting off. Need to check if drum turns freely. If it does check vent hose making sure it isn't plugged causing dryer to overheat. If motor is bad it will get worse and just not start
Sep 24, 2014 | Avanti D110 Electric Portable Dryer
D110 Avanti
i would say that the rollers that the drum rides on is need of replacing. But need to open it up and check.
Apr 19, 2014 | Haier Dryers
I have a Avanti dryer and after its on a few minutes it also cuts off. Can you tell me why or what to do to fix this problem?
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub.Replace the Heating Elements
Oct 17, 2012 | Avanti D110 Electric Portable Dryer
What material can I use to make a replacement lint filter for my Avanti D110 dryer? The original is about 9.5" round thin filter material that fits onto the screen lint filter. If I know what ...
Hi renfrorichte...
I would use fibreglass window screen cut to the size needed.
Bonded with a good glue such as 3M's Weather Proof Adhesive or Contact cement.
Please take time to rate me
Sep 05, 2011 | Avanti D110 Electric Portable Dryer
Whirlpool Dryer Model LER5636EQ3. Runs for several minutes then stop.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2011 | Avanti D110 Electric Portable Dryer
Haier HLP140E Electric Portable Dryer Logo
873 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
