Question about Maytag MSD2756G Side by Side Refrigerator
Won't let cold air flow from freezer to refrigerator
Coils in the freezer have frost on them and we have to get it off with a hairdryer every few weeks
  • 401 Answers
SOUNDS LIKE A DEFROST PROBLEM. IT MAY BE A HEATER,DEFROST SENSOR BUT MORE COMMON THE ADAPTIVE DEFROST CONTROLER. YOU NEED A METER TO OHM OUT THE HEATER AND TERMINATOR IT THE FREEZER (THE TERMINATOR NEEDS TO BE COLD) IF ALL IS GOOD THE ADAPTIVE CONTROL IS LOKATED IN THE UPPER FRESH-FOOD SECTION UNDER THE CONTROLS.
Posted on Apr 26, 2010
Hello, actually my Maytag refrigerator is 22 cu ft. bottom -mount freezer. I'm pretty sure my freezer is the frost less kind but it has started getting frost and almost snow in it. I was just wondering...
Hello
Any freezer will accumulate frost on walls etc, eventually.Mostly in the summer when there's more moist air and door openings. The fan is supposed draw all moisture to the evaporator coils so you won[t get the frost , So if it is excessive check to make sure refridgerator compartment is keeping cold.If it seems warm to you,you probably have defrost issues.
If ok ,then check door gaskets for air leaks ,(excess moist air gets in).Or excess food ,especially at bottom might block some air flow.
regards
Jul 28, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
My refrigerator is not cooling everythings seems to be working fine and I can hear the flow of refrigerant but it is not getting cold. Is it possible that it needs more refrigerant
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 10, 2011 | Dometic Refrigerators
I have a GE GSL25JFPBS side by side. Freezer works okay, but refrigerator does not. Coils in rear of freezer are frosted toward the bottom of the coils. I shut down the freezer, removed frost, blew out...
You wake up in the morning and go to the refrigerator to get some breakfast. When you get out the milk, juice or whatever it is you get for breakfast, you notice something is wrong. It's not cold! The next thing you do is open up the freezer and see if that is still working properly. Wheeew it is. But why?
What you probably didn't notice was that the freezer has not been going through it's normal defrost cycle. Because of this un-noticed event going on, there has been frost building up on the evaporator coils that doesn't belong there. After this frost continues to build up over the course of a few days to a week or so, now you are going to start to notice the effects.
Here is what's happening when you have a malfunction in the defrost system.
  • Air cannot circulate from the freezer(where the cold happens basically) to the fresh food section.
  • Your refrigerator will run constantly to try to cool the fresh food section. This will develop a new set of problems with your refrigerator. More on that later....
  • Excess frost builds up within the coils inside the freezer. This is what is blocking the air flow to the fresh food section
  • Usually you will notice the icemaker will stop making ice. Poor air flow and not quite cold enough temperatures in the freezer cause this
  • Water will not come through the dispenser on the door. Cold air settles, the water resovoir will freeze.
  • Compressor may overheat and shut off. This is when you hear, click, click, click. Not good
  • Ice Cream in the Freezer will start to get soft. That's really not that bad. lol
What can you do about this. Let me explain the defrost system in general so you get an understanding of what is going on.
The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the refrigerator section of your refrigerator. Every eight hours or so, depending on the type of defrost timer or control you have, the compressor and fans will shut off and the machine will go into defrost mode.When the refrigerator is in defrost there is a heater that is tied into the evaporator coils inside the freezer that comes on. This heater is behind the rear panel inside the freezer where the evaporator coils are located. It melts the frost that has accumulated over the course of time. After about thirty minutes the machine comes out of defrost and goes back to normal operation.
Now the air can continue to pass through the coils and keep the freezer frozen and the refrigerator cool and everybody is happy. you have to be able to do a continuity test on the defrost therrmostat as well as the defrost heater 79 precent of the time it is the thermostat that is defective if you receive both postive results after testing both of these and they both passed your continuity test then you would look at the defrost timer or in some models the board on the back side under the panel of the fridge if you have any further questions message me back and please remember when this chat has concluded to rank how this opinion has helped in your appliance situation so that i may continue to help people like yourself in the future with similar situations Thanks again Rick
Jan 22, 2011 | GE GSL25JFPBS Side by Side Refrigerator
The freezer is working good, but the refrigerator does not cool. there was frost built up in the back of the freezer, Defrosted it, but it did not help. ,
The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the refrigerator section of your refrigerator. Every eight hours or so, depending on the type of defrost timer or control you have, the compressor and fans will shut off and the machine will go into defrost mode. When the refrigerator is in defrost there is a heater that is tied into the evaporator coils inside the freezer that comes on. This heater is behind the rear panel inside the freezer where the evaporator coils are located. It melts the frost that has accumulated over the course of time. After about thirty minutes the machine comes out of defrost and goes back to normal operation.
Now the air can continue to pass through the coils and keep the freezer frozen and the refrigerator cool and everybody is happy. Therefore you should do continuity test on the tstat the heater and check the fan as well the last thing that you would check would be the defrost timer all three of the first parts can be found behind the back panel in the freezer If you have any further questions please remember when this chat is concluded to rank how this opinion has helped Thanks again Rick p.s we love 4 thumbs for answering free chats lol also if there is ice built up in the back of your freezer defrost it with a hair dryer Thanks again Rick
Dec 28, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer & fridge not cold enough, frost in freezer
Refrigerator or freezer is not cold enough
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 31, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
My frigidaire refrigerator is not cooling anymore. The light is on. The motor is running. What is wrong?
if one of the panels in the freezer has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | Frigidaire Refrigerators
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
LBF6
Frost over the box tells me that you do have refrigerant flowing through the evaporator coil. If the coil has a defrost element as you stated it should also have a fan for circulating the cold air. Apparently your fan is not operating.
Jul 26, 2008 | Freezers
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
115 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
