Question about Ariston Technologies Dishwashers
Ariston LS 2020 taking more than two hours to go through cycle.
Just moved into a rental property with an Ariston LS 2020 dishwasher. Have instruction book but no idea of how long a cycle should take. Has been washing now for nearly two hours and still not finished.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Posted on Apr 26, 2010
  • joyce2011 Aug 09, 2011
    hey dyan18, do you still have the instruction book for LS2020 'cos the previous owner doesn't leave me one. Would you mind to scan it and email it to me? Having a hard time finding the manual online. Thank you.
  • kalm57 Aug 10, 2011
    hi joyce2011
    I have the same problem
    Do you still have the instruction book (manual) for LS2020 'cos the previous owner doesn't leave me one. Would you mind to scan it and email it to me? Having a hard time finding the manual online. Thank you.
If the Ariston takes more then 2 hours to finish it's cycle, the cause could possibly be the heating element. Mine was taking around 3 to 4 hours to complete the cycle. on inspection I found cracks in the heating element, Once the element was replaced it returned to the normal 2 hour cycle.
The dishwasher had been running great for around 6 months, now the wash pump is arking and causing great concern. Apparently water was slowly leaking onto the pump as the lower wash arm lock nut had loosened slightly. No looking for a cheap replacement pump.
Posted on Dec 26, 2011
Can anyone tell me about the washing cycle symbols on my Ariston LS12.EV03. It came with the apartment with no manuals...
Best I could do for instructions in English: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Ariston/Dishwashers/AF350X_034628gb.pdf
Here is a site with a lot of manuals for Ariston products, with other brand names: http://www.manuals.club/results_alpha.php?ctext=ARISTON+DISHWASHER+LS12-EVO3
Mar 05, 2015 | Dishwashers
F&P Nemo Dishwasher
I will assume the model number is DW820. Looks like the foaming is causing the problems. The foam is getting into the dishwasher motor chamber and triggering the flood switch intermittently. This causes beeping. Switch to a recommended detergent like Finish and only use enough powder for the selected wash cycle. Refer manual pages 20/21 at this site.
http://data.manualslib.com/pdf/6/519/51837-fisher__paykel/dw820.pdf?232bba8b0235436687c0af09b9e1acd4&take=binary
If this is not your model then provide the actual model number usually printed on a sticker at the side of the door.
Apr 21, 2014 | Fisher Dishwashers
Ariston LS 2020 dishwasher is tripping mains switch at several points of washing cycles. What's wrong with it?
It probably uses more electrisity than there is avaliable at peak preformance. It is safer to contact an electrician to have him measure the use of electrisity and why there is this sudden use.
Jun 14, 2010 | Washing Machines
Ariston dishwasher LS609 the cycle nob does not
Had the same problem with my 12 year old LS609. The cycle knob sits on top of what Ariston calls the control board. This control board is most likely to be your problem. It was in my case.
May 14, 2010 | Ariston Technologies LL64WNA Built-in...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
 we recommend u to perform the following checks on ur dishwasher,
  1. Test the timer motor
  2. Test the thermostat
  3. Test the heating element
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
Apr 08, 2009 | Dishwashers
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
Dishwashers Logo
1,151 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
