Question about Sony DSR-11 DV / Mini DV VCR
Playing Tape to End Requires Head Cleaning Every Time
The heads to my Sony DSR-11 seem to need cleaning every time a tape plays to the end. If I just play the tape up to the last 4 minutes or so, it plays fine over and over again, but if I let it play until it stops (at the end of the tape) it looses time code, or plays with bars and pixelation, or not at all...
If I run a head cleaning tape it seems to work fine again??
I keep all of my machines clean, so I don't suspect cross contamination, nor do any of my other decks display any problems playing the same tapes??
Any ideas?
Thanks!!
  • questech Apr 27, 2010
    Thanks for the tips!
    The tapes are not damaged, so the unit isn't mangling them at least.
    It's weird though, when the DSR-11 is first fired up and a tape is played for the first time, it plays through without a glitch, and I can replay it as long as I don't let it get all the way to the end of the tape.
    Also weird, if it does play to the end of the tape, either I'll get bands and pixelation, or no timecode & no playback... it doesn't even see the tape.
  • 80 Answers
It seems your tracking needs to be looked at.also have a look at the tape open front section button at side slide open with your finger.look at the tape toward the light,if the edge of the tape is a bit wavey not straight you will need an alighnment as well.
Posted on Apr 26, 2010
  • Martin Smith Apr 27, 2010
    I HAD THIS PROBLEM ONCE AND HAD THE TRACKING DOWN ON IT,MINE ALSO LOST COUNTER WHEN PLAYING TAPE.I HAD SIX VCRS AT. THE TIME AND CHECKED TAPE ON OTHER MACHINES FINE .PAIN IN THE NECK WHEN ELECTRONICS GO WRONG.GOOD LUCK.
Tape loads into Sony DsR1500P but will not play or rewind/fast forward. No error code shown. Time code does not turn over.
Dear
Please play a head cleaning cassette and after using it for few seconds then play a normal tape.
Then it will show the picture.
Sep 10, 2013 | Sony DSR-1500 Mini DV VCR
Tape deck wont accept tape
head may be dirty...May need cleaning....theres a product sold out there that requires that u drop a solution to the head cleaner and insert the head cleaner into the deck...u will need to run the cleaner a few times as if u were playing a regular recorded tape...this process cleans the head...if thats the problem...
Aug 04, 2012 | 1998 Toyota Camry
Error 02-603
uR error means 02:603 Detected slack tape during PLAY and REC.This thing happen.
1 if your tape is have moisture in it
2.IF You have over use your TAPE more then 100 times
3.if there dirty in tape parts and pinch roll and head drum
So clean the tape part head drum ,with Sony cleaning cloth Manley .The re set all the error by going to maintenance menu.
Mar 01, 2011 | Sony DSR-80 DV/Mini DV VCR
While playing a tape, there is no sound, and video on the left 20% of the screen freezes with varying amounts of video that appears in small slowly changing rectangles from earlier frames. Video on the...
Two possibilities, either player needs tape path adjustment or requires drum (video head) replacement.
Above said solution requires expertise and Sony trained tech will do this job with proper tools.
Thanks.
Jul 08, 2009 | Sony DSR-1800 DV/Mini DV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Sony dsr-45 tape
It is:
Sony cleaning cassette DVM12CLD you can buy it from ebay at 15 pounds. click on the following link:
http://cgi.ebay.co.uk/Sony-DVM12CLD-MiniDV-cleaning-cassette-in-Blister-DVM12_W0QQitemZ370257959235QQcmdZViewItem
Aug 07, 2008 | Sony DSR-45 Mini DV VCR
D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony DSR-1800 Lost Lock
check the condition of the pinch roller. a bad pinch roller can cause this problem - a tape plays for several minutes, then has problems. what happens is the tape slowly moves up or down on the roller instead of traveling in a straight path. this is caused by the roller becoming worn or glazed and not being able to provide traction to pull the tape through.
Sep 24, 2007 | Sony DSR-1800 DV/Mini DV VCR
Trouble recording to DV Tape
Hello, cleaning the head and the tape path with cleaning tape is a good idea. Try it! If the cleaning does not help the video head is damaged. If you need more info please advice.
Feb 16, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony DSR-11 DV / Mini DV VCR Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
