Question about Jenn-Air JLG7130A
Electris ignition is not working when each knob is turned. I changed the battery and still no juice, whats the prob?
  • 140 Answers
Your starter where your battery is, is bad replace it and you are ready to go
Posted on Apr 28, 2010
Kia optima hybrid 2012 not electrial function at all, the car is no working no ligths,not ignition complete dead what I need to do?
Did you replace the battery recently?
seem like your main fuse many may be 100 or 120amp fuse is blown and not powering little fuses.
Feb 18, 2017 | Kia Optima Cars & Trucks
Range rider bugy with a kawasaki fc290v electronic ignition with a fully charged battery i turn the key and get nothing any ideas ?
I would say you should check to make sure you are getting juice to the starter when you are trying to start it. This can be done with a simple voltmeter or 12v light tester. If you are getting juice, then the issue seems to be a bad starter. If you are getting juice the it could be the solenoid, ignition switch or a simple loose connection. I will be more than happy to help you get this up and running. First start by testing to make sure you have juice going to the ignition switch and the starter when you turn the key.
Jun 25, 2012 | Cars & Trucks
My 92 Honda Accord LX manual started cutting out like it wasnt gettin no gas and this was after i changed the fuel pump. And most recently I will push on the gas and it cuts out and kills the battery I...
Hmmmm....bad ignition switch?
Bad battery ground cable?
Loose or corroded positive battery cable
Bad engine-to-frame ground cable? Hope this helps, James Booth. Please rate this... :)
May 18, 2011 | 1992 Honda Accord
Miele KM 342 - I have burner - will ignite when knob pushed in but once release knob flame goes out
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
Aug 07, 2010 | Miele 36 in. KM342 Gas Cooktop
2004 t&c minivan. only 35k miles. Radio/Nav head unit works when key is in Acc mode. No power to radio unit after key is turned to ignition. This only started happening after changing the battery...
The reason the radio and all other units go off when you turn the key to ignition is all the juice is being sucked by the starter motor ( happens to majority of the cars and is very normal). and if it didn't used to happen to you before is probably you had a battery with higher Amps before. Hope this helps.
Feb 15, 2010 | 2001 Chrysler Town & Country
2003 jetta gl manual trans-positive battery and ground starter cables replaced...now have plenty of juice going to starter...but it grinds when i turn the ignition...now it doesn't start at...
I presume you mean 'grinds when I turn the ignition..(to start)'.
If this is so, it's most likely the starter motor 'drive (overun) clutch is faulty.
Either replace the starter motor complete or replace the drive clutch assy on the original.
The latter should be cheaper (especially if you can source a new 'drive clutch' and fit it yourself).
Nov 13, 2009 | 2003 Volkswagen Jetta TDI
New starter but car wont start
funny...you have just told me what is wrong with it!!!
check power in, power out at the ignition switch...likely it has failed. switch is on the top of the steering column under the dash and is sometimes easier to reach if you disconnect the column from the dash and permit the sterering wheel to rest on the seat.
Apr 16, 2009 | 2004 Oldsmobile Alero
Cold weather Car won't start, but fan under hood does
Because ur lights ar eon when u turn the ignition key doesn't necessarily mean the battery has juice. It probably does to do those things, but it probably doesn't have the cranking amps to send to the starter so that it can turn over the engine. But if the battery is good, it means that ur starter is not working properly, because u said that the engine isn't turning ove. Try tapping the starter a bit and c wut happens. Sometimes it works. If unsure, consult with an auto-electrician. This is definelty an elcetrical probelm
Jan 29, 2009 | 1986 Toyota Celica
Grilling Logo
139 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
