Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
How do I get the motor housing apart on a minn kota 30 trolling motor. I removed the armature, but I can't get at the brushes to fix and replace them. Thanks Tim
  • 157 Answers
SOURCE: Minn Kota 30 transom mount motor magnets fell out during service
Hello Bob, Contact www.minnkotamotors.com/index.asp choose ext#406 ask for Dave. He is a good guy. Merry Christmas.
Posted on Dec 05, 2008
  • 10 Answers
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
SOURCE: Minn Kota power drive trolling motor will not
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Posted on May 26, 2009
Editor925
  • 285 Answers
SOURCE: where to buy replacement brushes for electric
http://www.northlandmarine.com/MinnBushKit3.25.htm
Posted on Jun 20, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Endura 30 Trolling Motor specs
    call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
    Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
    MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
    Hi!
    Here is a schematic for your motor:
    Endura 30
    It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
    Best of luck!
    Mike
    Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
    TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
    Hi!
    Here's a schematic:
    Max 74 Bowmount
    Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
    Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
    Best of luck
    Mike
    Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn kota endura 30 repair
    The top section will pop off when the six screws are removed. It might just be dirty and sticking.
    Apr 12, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Model 35 24lb thrust transom trolling motor not getting power
    It might help to view drawings at http://secure.northlandmarine.com/MinnkotaTillerSteering.html.
    The spring loaded items are brushes. They carry current to the rotor/shaft/impeller causing them to spin. I have two Model 35s. One failed after a couple hours of use. The other was given to me because it did not work. Both suffer from water getting into the motor and causing corrosion and sticking brushes. Someone on another site commented that this was a common problem for Minn Kota.
    Jul 17, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota tolling motor
    Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
    Nov 24, 2007 | Minn Kota Maxxum 70 Universal Motor/Sonar...
    Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
    116 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
