Question about Epson Stylus NX400 InkJet Printer
I lost the manual and I can not figure out how or where to loan the paper to print
    President:
  • 3,278 Answers
Hello, Patty.
Here's the Quick Guide from Epson for your printer, which shows how to load the paper:
http://files.support.epson.com/pdf/nx400_/nx400_qr.pdf
Hope this helps.
Posted on Apr 26, 2010
6110xi leaves a dark line on the right 1/3 side of the printed page. It usually looks like just a pressure impression mid print and sometimes leaves other 1/2 spaced ink smears on the borders. The...
Print is skewed
  1. The rear access door might not be fully locked into place, causing the paper to skew in the all-in-one. Remove the rear access door by pushing in on both release tabs as shown in the figure below. Inspect it for damage, and then reinsert it. Make sure it is securely latched in place. Figure 6: Releasing the rear access door latch on one sidec00222462.jpg Figure 7: The rear access door removedc00222463.jpg
  2. The paper feed rollers may be dirty. Over time, paper fibers and dust will stick to the rollers and should be removed.
    1. Unplug the power cord from the back of the all-in-one and open the front to expose the print mechanism.
    2. Gently wipe the paper feed rollers with a soft clean cloth slightly dampened with clean water. These rollers may be rotated with the power unplugged.
    3. Remove the rear access door shown in the figure above and wipe the paper supply feed rollers. These rollers may be rotated with the power unplugged. Allow the water to dry for five minutes before reinserting the rear access door and locking it in place.
    4. Close the all-in-one and reinsert the power cord.
Apr 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a brother hl-5250dn with an extra tray for legal size paper. I have a problem printing loan documents sent via swiftview or elynx. I can only print on letter pages or legal pages but not both and...
Sounds like your secratery's printer is set to ignore paper mismatch errors. It depends on the setting you have in your driver. Can you set your driver on your printer to ignore paper mismatch errors. If not when your printer errors, just try hitting the go button and it should print the document any way.
Sep 07, 2009 | Brother HL 5250DN Laser Printer
Can't figure out how to print on statement sized paper.
After I had been attempting to adjust the paper guides in the feeder tray to accommodate statement-size paper, I finally "discovered" the drop-down door to the manual feed tray.  Duh!  This is a networked printer that I've only ever used for printing letter and legal sized documents until now.
May 28, 2009 | Lexmark T640 Laser Printer
Lost manual need help with paper settings
Go to My Computer, next Control Panel and then Printers. Right click on the printer and go to "Printing preferences" You can change it there.
Mar 13, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
The figure 8 light with the check, first symbol on my Hp Laser Printer P2015d is blinking. The printer will not print
the figure 8 light means paper jam.
check all of the paper path, from the paper try to the output, and fromt the manual feed tray to the output.
Dec 08, 2008 | HP LaserJet P2015dn Printer
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
Having trouble trying to figure out how to get the paper set.
As this card is not suppourted by the all-in-one. We need to manually set the size of the card in custom settings under print settings in HP Solution center. Also choose paper type as plain paper and click OK.
After entering the size of the paper and giving it a name, once close and reopen the solution center and then select the name which we have given to this size and click OK and try to print.
May 20, 2008 | HP Photosmart C6280 Printer
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Epson Stylus NX400 InkJet Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
