Question about Lexmark X1240 All-In-One InkJet Printer
Wont print it says it has a bad connection
    Genius:
  • 3,587 Answers
Could be..unhook printer..run test page from menu..reconnect with power off..turn printer back on..see what happens next
Posted on Mar 23, 2008
SOURCE:
Why wont the Headlight and Highbeam indicator wont work
Does the headlight itself work? Will it switch from low beam to high beam? If the lights work but just the indicator is bad, then perhaps the problem is in the indicator socket (corrosion or loose connection) or the wiring to the indicator (bad connector, break in the wire or printed circuit board trace). If the lights don't work, it could be the handlebar switch is failing but it's more likely to be the wiring coming from the bars to the handlebar pivot area.
May 06, 2014 | 2006 Honda VTX 1300 S
Printer wont connect to network and now won't print via USB
Dear, Model no not mentioned, If its not printing through net work or USB it might be formatter faulty,,replace it..
Jan 31, 2012 | HP Office Equipment & Supplies
Myhpj4680 printer wont stop printing the same thing over over over
What print it is?. >Might be askew codes are printing. remove usb cable, cancel all the pending documents, un install the drivers. Once system cleared every thing restart the system,load printer drivers with original cd..when system asked to connect the printer.. Switch off the printer wait couple of minutes..connect the usb cable.. complete the drivers installation..check for print..
Wont print magenta despite deep cleaning and nozzle head cleaning. Its a new cartridge. It wont print sotred docs or photocopy in magenta it comes out yellow/green colour
Hi the bad news is you need a new print head and they cost about £47.00
go to amazon or google Canon PIXMA MP620 print head and you will get a list of suppliers
Very simple to fit
Ian
Mar 11, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I replaced ink and now will not print. I have unplugged turned off and restarted but still will not print.
It is possible that when the ink was replaced there could be conflict with the software so unplug and reinstall the software then connect the printer and check. If the printer works but if this wont print, then it is possible that the heads are dirty or the printer head is bad.
Try to use the maintenance key to clean the head if this wont work then it is possible that the head is bad.
Hope this advice helps.
Aug 21, 2010 | Computers & Internet
Sometimes works perfectly other times wont even come on model lcd w9za
ronniecam, Likely it's just one bad thermally intermittant solder connection on units internal "switch-mode-power-supply/ inverter supply printed circuit board or bad swollen/leaky electrolytic filter capacitors. Do some reading in my and other LCD technician's fixya profiles for more info on this very common problem. 12fixlouie
Mar 16, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Wont print from digital camera
Look in your camera settings and change the connection from USB to Pictbridge. If that's possible then you should be able to connect.
Dec 29, 2009 | Polaroid PoGo Digital Photo Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Printer will not print
i cant print it wont print anything.can you help
Nov 12, 2007 | Lexmark Z640 InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
