Question about Weber Spirit? E-310 Propane Grill
Weber Spirit one month old...went out, changed tank, won't light
Weber Spirit
It's one month old, went out while cooking. Changed to a new tank, now it won't light.
  • Anonymous Mar 17, 2014
    change batery weber spirit
    Guru:
  • 1,051 Answers
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Posted on Apr 27, 2010
CAN I CONVERT WEBER SPIRIT E32 PROPANE TO NATURAL GAS
you can change them but you need to change the jets there are conversion kits for the weber cooking systems.
Aug 06, 2017 | Weber Grilling
Weber Spirit 210 Won't Get Hot
Try following these steps to reset your FLD (flow limiting device)http://www.edyoungs.com/edyoungs/troubleshoot_tank.htm and then carefully follow the lighting instructions. If it works for you I think you will find this is a GREAT grill! Happy grilling and eating!
Apr 19, 2014 | Weber SPIRIT E-210 (NG)
Bought this grill in june/july. first tank worked perfect. tank went out while cooking. changed to new tank and lit her up. low flame and went out. looked at tank and found the valve and hose covered...
turn off gas at tank remove hose let it deforst , open all burners on bbq run out gas in line , turn off burners, reconnect tank turn on slow , check hose for leaks with washing up liqued and water mix make bubbles with this mix and brush over joints this will prove if you have a gas leak (hence the frosting ) if this is good no leak then you should be able to light burners , if this leaks then it could be a new hose.
Sep 24, 2011 | Weber Spirit SP-310 Propane Grill
Grill will not get over 300 degrees and it is only 2 months old. Has worked fine until now. Changed propane tank.
It could be a bad regulator you can get one from home depot if that does not work call Weber grill and they will send you parts for free!!
Aug 29, 2011 | Weber Grilling
My 2 year old weber E-210 gas grill does light. I replaced the igniter, but I do not hear any propane gas being sent to the .I have also tried to manullay light it with a match, and nothing. HELP!
If you have recently bought a new propane tank you may have gotten a bad one. Try taking it back to the store and asking for an exchange. The valves go bad inside the tanks sometimes.
May 29, 2011 | Weber SPIRIT E-210 (NG)
My weber spirit 310 igniter will not work. It does not click or make a spark. I have changed the battery. I did notice that the battery chamber was very corroded so I cleaned it out but still no click....
I suspect that the corrosion you found has taken it's toll. You will need to replace the the ignitor box.
if it's still under warranty, Weber may cover it. Either way, you can get the part from Weber on line. Make sure you have your Model #, Serial # of the Grill and the date and proof of purchase.
Feb 13, 2011 | Weber Spirit? E-310
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
The heat on m Weber grill would not go above 250 degrees even when the grill was lit for 30+ minutes. I changed the gas supply hose and regulator & fixed the problem. The next time I used the grill...
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 28, 2010 | Weber Spirit? E-310 Propane Grill
Heating
It sounds like the regulator is shutting down and preventing the grill from getting all of the propane it needs. to remedy your problem disconnect the tank and then reconnect it. Usually that is all it takes to get the regulator to work properly. If the problem continues just get a new hose with regulator attached.
Jul 07, 2009 | Weber Spirit? E-310 Propane Grill
Weber Spirit? E-310  Propane Grill Logo
575 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
