Question about Garden
Bolens Q683H 8 speed lawn tractor will not go into neutral.
My Bolens lawn tractor will not go into neutral and will not start. It had a tune up a year ago but the rear wheels are locked up and there is no sound at all when you try to start it. It appears the linkage underneath is moving but it is not going into neutral. Any help would be appreciated.
  • cat4reid Apr 26, 2010
    I will check that out, but the rear wheels will not turn either, so it appears that it really isn't going into neutral.
    President:
  • 2,468 Answers
Is the neutral safety switch located underneath the riders seat on this machine being depressed fully to make connection or could this switch be bad,if its bad the unit will not start,because the seat,transmission switch,and start circuit are in series and one that isn't closed(as in a switch) will not pass current to the start circuit
Posted on Apr 26, 2010
  • danny Hendrickson Apr 26, 2010
    can you ruc a jumper cable directly to the starter and get it to turn over and start,it may be locked into gear and by bumping the starter you may be able to knock it back out of gear unless there it a thru shaft broken inside the transmission
  • cat4reid Sep 11, 2011
    Turns out one of the switches was dirty. Wiped it with a rag, plugged it back in and it started.
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Have Bolens lawn tractor, 15.5 HP B&G engine 2005
It is a fuel cutoff solinoid, backfire prevention solinoid. If it fails then you will get no gas into carburetor. If you turn the key from off to run and it clicks then it is working, if it does not click then there is a problem.
Aug 24, 2011 | Briggs & Stratton Garden
I have a bolens bl150 gas trimmer and the problem is that it stards but won't stay running. it starts and it diey it starts and dies over and over again. what could be the trouble?
  • Check the fuel mixture and make sure it is correct.
  • Clean the air filter if needed.
  • If everything else is fine then you may want to try and adjust the idle speed screw. The screw is located on air filter/muffler cover.
Turn the screw "clockwise" to increase the idle speed. Only turn it about 1/8 of a turn at a time (as needed) until the engine runs smoothly.
If it still doesn't run properly then you may need to have the carb cleaned.
Bolens BL150 Manual
Mar 18, 2011 | Garden
I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Feb 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Bolens 13am662f163 wont move.
sounds like the varabel speed pulley is locked up ck that
Sep 06, 2009 | Garden
Garden Logo
662 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
