Question about Taylor 632-27 Ice Cream Maker
I am looking for a gearbox for a taylor 777-27 used need tomorrow
Need gearbox for a taylor 777-27 used
Taylor c712 with pumps one side sounds like it is pumping and looks like its pumping but when you use it there is no mix in the barrel
Hi Megan,
The first thing I would do is tear the machine down, sanitize and rebuild and properly lubricate everything. If you have a spare kit, you should install all new pump o rings and seals (Parts 4, 5, 6, 8 and 14 in the schematic). Hopefully, it is either improperly lubricated o ring, or a worn out seal and that will fix it.
The plastic pump parts do wear out over time (Parts 3 and 4) and so do the stainless steel pump sleeves (Part 1). If seals and lubrication don't correct the issue, you can start looking closer at the pump parts.
I have the tune up kit available here.
http://www.softserveparts.com/i-26471781-x49463-81tune-up-kit-for-taylor-c712.html
Schematics of the pumps are here with prices and part numbers.
http://www.softserveparts.com/p-37364-exploded-parts-views-for-taylor-c712.html
Soft Serve Parts C712
Jun 18, 2017 | Taylor Ice Cream Makers
My taylor 152 only makes about 5 ice creams then won't produce any more for about 6 minutes ... why ??
The Taylor 152 is at the low end of output when it comes to commercial soft serve equipment. It is rated for 102 3.5oz. servings per hour, but only 4 3.5oz rapid servings before it needs time to recover.
Possible remedies:
When you need to serve several cones in a row, you can pull the feed tube in the top. That will help the product fill the cylinder a little faster.
You could always consider a used Taylor machine that has the ability to keep up with your demand. Soft Serve Parts Taylor Machines
Apr 07, 2017 | Taylor Ice Cream Makers
Do you have a service manual for the Taylor Model 702?
being a fellow fixya guy, you will know that fixya does not have anything except advice
go google and type in --service manual for taylor model 702--and look for a pdf version
Oct 03, 2016 | Taylor Ice Cream Makers
I AM TRYING TO FIND A PART FOR A TAYLOR ICE CREAM MACHINE, SHE GAVE MOD # 8054248. I CANNOT FIND A MANUAL FOR THIS # THANKS
that looks like it might be a serial number that is missing the letter in front on it, you need to have the proper model to look it up
Jul 21, 2011 | Taylor 632-27 Ice Cream Maker
Taylor 8756. Electrical service too high???
As a general rule, most unit can handle a voltage of =/- 10% of rated voltage. I would call Taylor to be sure. You can get a "Buck and Boost" transformer that would lower the voltage but you may not need to.
http://www.taylor-company.com/
Go to this web site and look up your local distributor or contact them directly.
Mar 20, 2010 | Taylor 632-33 Ice Cream Maker
Taylor Y754-27 Soft Serve Ice cream machine
Gearboxes definitely go bad. The first sign is usually noise, I would describe it as a rumbling. The best way to determine if it's the gear box is:
1. empty and disconnect machine from power.
2. remove the freezer door and beater assembly
2. remove the rear panel - 4 screws
3. Remove the belts on the noisy side
4. Spin the big pulley and listen for the noise, you may want to remove the belts on the quiet side to compare the two.
I have a video that was shot to help change the hex coupler, but you would follow all of the same steps to replace the gear box.
Dec 12, 2009 | Taylor 632-27 Ice Cream Maker
Taylor ice cream maker single serve
You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
Oct 19, 2008 | Taylor 632-33 Ice Cream Maker
Taylor soft serve ice cream machine model #y754-27
I have a gearbox,coupler,pulley etc. pulled off a y754-27
Jer 805-925-5556
Sep 30, 2008 | Taylor 632-33 Ice Cream Maker
Spares for Taylor 8756 ice cream machine
you must buy replacements from your local tatlor dist. 700-900$
You will find that responce from all of thier part suppliers carrier is a very well insulated company.
Jul 29, 2008 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
129 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
