Question about Jandy Laars Lt 250,000 Btu Heater
Temp sensor light is on and it will not heat. Just had the filter cleaned proffessionally last Wednesday
    Top Expert:
  • Jandy Master
  • 6,394 Answers
Replace temp sensor shorted or open keep an eye on your chemicals
Posted on Jan 30, 2016
My 2006 hot spring grandee spa won't heat.
Have you checked the heating element? Is the spa showing it is heating up but does not? That would indicate a bad temp sensor.
Rod
US Parts Center
Jan 06, 2014 | Intex Pool & Spa
Heat pump?
There could be several issues at work here.
  • First, is the heat indicator light showing on the topside?
  • Is the pump running but temp is not rising?
  • Any error codes displayed on the topside panel?
The drop in water temperature could be caused by a faulty temp sensor or faulty high limit sensor.
Check those items out and see what you come up with.
Rod
US Parts Center
888-521-6183
Mar 14, 2013 | Pool & Spa
Red Light flashing
it may be because of the problems as u described air filters and fan .but try first with the filter,u can find it at amazone or flipkart
May 03, 2017 | Epson Computers & Internet
My AC 1200BTU work in heating 5min. and than stopped
Check temp setting and also room sensor. Setting must be minimum 3 degree more than room temp. Check continuity for sensor. If open replace it. Check coil , air filter and heater element are cleaned.
If high amps, replace heating element. Thanks.
Feb 07, 2011 | LGLXA1230 Air Conditioner
When I turn on ac, temp in room comes down, temp on machine reads 95F could problem be exhaust hose has some tears?
The temp sensor is located on the upper rear just behind the air filter. Slide the filter out and give it a cleaning. Look for a small wire visible. Inspect the temp sensor; it gets dusty.
If the hose was leaking you would feel the heat in the room.
Jul 09, 2010 | Danby DPAC120068 Air Conditioner
Carrier furnace will not heat house. Turned circuit breaker off and on again and it will kick heat on but only heats to move temp up 2 degrees. LED light is continuously on. All the manual says is 24 vac...
Sounds like it will not stay on long enough.I would try cleaning the flame rod/sensor.A steel pin next to the pilot or near the last burner to the left.Has a wire attached to it polish it with fine grit sand paper.
Mar 24, 2010 | Heating & Cooling
Dryer wont heat and check filter light is on but filter in dryer is clean?
This could be caused by a venting restriction. These dryers have sensors built in to check airflow temp differences. Take the vent off the dryer and run it and see if it heats. If it does then you know the problem is with your venting. You will need to either clear the vent or replace it.
Hope this helps _MJ_
Feb 01, 2010 | LG DLG5932W Gas Dryer
See description to the left
Ford 1989 F 150
Is this 4.9 L (6) cyl. ?
Truck runs until hot then quits. Cools down then runs again.
You can get error codes. Many auto parts stores will have free loaner meters to read them.
It could be the hall effect sensor in the distributor. You need to test for injector pulse and if you don't have a pulse, the hall effect sensor will be suspect. This sensor checks for crankshaft position in earlier models instead of a cranks position sensor. The TFI module plugs in near it.
Use a noid light for Ford plugged into an injector and crank the engine to see if it lights.
May 30, 2009 | 1989 Ford F 150
Heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Mar 14, 2009 | LG L1004R Air Conditioner
No heat and filter care light constantly lit
Have you cleaned the filter and the filter compartment?
Try that, then unflug it for about 10 min, then plug it up and try it again.
This will reset some units with an auto reset high temp limit switch.
What happens when a filter gets dirty/clogged is that not enough air is blowing accross the heating device. This lets it get to hot and it will shut off for safety to prevent fires.
If everything is clean and after pluging it back up it still gives you that code you may have a bad sensor.
Dec 06, 2008 | Dryers
Jandy Laars Lt 250,000 Btu Heater Logo
48 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
