Question about Lexmark X1240 All-In-One InkJet Printer
Cartridge replacement my new printer had a sample cartridge,it now says ink level low so i bought a black one, still says low ink ,still trys to just print in color
  • 667 Answers
Try doing a print head alignment. This will let the printer know the cartridge is full. Any further questions just add a comment and I'll be glad to help you out.
Posted on Mar 24, 2008
Panasonic all in one printing quality problem
Is the problem you are having streaking? Color or B/W?
Most inkjet print problems require either cleaning or replacing the cartridges. Does your printer indicate low ink levels? New printers come with sample cartridges that do not last very long. I hate to say it, but buying the manufacturers cartridges will avoid most future problems. But try the cartridge cleaning program first if ink levels are OK.
You can also find how to remove the cartridges and clean the inkjets on UTube. But messy and time consuming. Better to bite the bullet and buy new ones if you can afford them.
May 04, 2016 | Panasonic Office Equipment & Supplies
Why won't my printer print black ink?
U may want to check the settings, sometimes with a few printers I've owned they give an option of using only color inks in cases where the black ink is out.
Aug 01, 2014 | Lexmark S415 All-in-One Wireless Color...
Need to print using hp 6110 with only black ink cartridge
Try to reset color ink level ,see how in the following link
http://atta-metro.blogspot.com/2010/03/reset-ink-level-printer-hp.html
after you complete , reset make sure your file free form colors , other wise print will ask you for change color , hope this help you
Mohamed Hejazi
Afaqnama - Tripoli Libya
Ipg@hplibya.com
Mar 21, 2013 | HP OfficeJet 6110 All-In-One InkJet...
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Ink low indication on HP Deskjet F4288
hi im josh in cebu phils.may i help you? Friend the problem is the ink level dropped 3/4 after printing 7 pages and low exclamation mark in red. Friend it is the real deal since you are using a free ink cartrdge with your printer that ink is only a sample one and the content of that cartridge is not full thats why it dropped to empty in just a few pages of printing. It just appear full in the ink level monitoring since the printer auto detects new cartridge on the tank. It is just so You need to buy a new ink cartridge the one with the full content.and i'm sure it will last a long time since it is already full. thats all friend good luck hope i helped you.
Mar 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Not printing
The remaining levels of the following ink cannot be correctly detected.
Color
The following ink is running low.
Black [830]
Prepare a new ink cartridge.
The resulting print quality may not be satisfactory, if printing is continued under this condition.
If either black or color ink cartridge has run out, you can set the printer to continue printing with the other cartridge from the Ink Cartridge Settings on the Maintenance tab of the printer driver.
----how to resolve it
email me: akemzone@yahoo.com
Feb 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
