Pet Vet cd
The cd won't play & I'm getting this error mesage.
Error code - line 87 d3dxerr do you want to debug application
    Master:
    Sergeant:
  • 482 Answers
You may have the wrong windows, vista dont run any thing thats windows xp or 98 or 95.
Posted on Mar 23, 2008
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
A Runtime Error has occurred. Do you wish to debug? Line: 0 Error: 'auto' is undefined. This keeps popping up, please help its driving me mad.
I would assume that the same application is always causing the problem. Usually the application or driver will have an update. You are getting an error from Windows telling you an application has done something it does not like.
Do you know the application causing the problem?
Apr 29, 2011 | Microsoft Computers & Internet
Runtime errors
Solution:
i) usually whenever there is virus, spyware, ... in your system some of the .dll will be lost or will lead to curruption or partial currption(some data or all the data in the .dll will be lost)
ii) as such some .dll files are heart or important to run system, some .dll files play mere role.
iii) when such .dll files are lost the program using these .dll files cannot locate or find their .dll files in such you get errors message as u said......
iv) as u debuging is not possible in the normal way until unless you have some debugging program or software such as "Visual Studio 2005" or Visual BASIC TOOLS....
v) due to loss of some important .dll files your system might shutdown frequently..... but you are fortunate that you are getting error message....and these .dll play mere role....
vi) i would suggest to install some best rated antivirus, spyware( Bit Defender -rated top, AVG, Norton....) after perform full system scan try reinstall your OS or format your system or load OS Freshly....
Thanking you
M. Sridhar
Dec 27, 2008 | Computers & Internet
I installed program ( Pet Vet) completely; however, when we went to play program the following errors occured: Line 87 DEDXERR invalid data 00x88780b59 terminating in an unusual way c: program...
It may be an address violation. Uninstall the program.delete folder pet vet from c:/program files. restart the system. reinstall the application. If possible install into some other drives like d: or e: etc
May 24, 2008 | Microsoft Windows 98 for PC
System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
Mar 29, 2008 | Microsoft Windows 98 for PC
I'm playing Pet Vet 2 and i got it installed but once i clicked The Pet Vet 2 button it said Pixel Shader unavailable
there must be a problem to your video card.. try to change the resolution of your video card and the setting of the game..
Mar 26, 2008 | Computers & Internet
System Code Error 87
Sounds like the application you are running may not be compatible with Windows 98. Probably can't do much as Windows 98 is so old.
Although it may be a missing file, DLL, or driver on your Windows 98 system, hard to tell.
Jan 11, 2008 | Microsoft Windows 98 for PC
Pet vet PC CD
The only documentation I have been able to locate on this issue indicated to reinstall the program, and this solved the problem for at least one user. However, they did not report a video memory issue. According to the program documentation, a minimum of 64MB of video memory is required for this program. So, if you do not have that much video memory, the game will not work properly. Best solution - reinstall, and if it does not work, check your video memory. If under 64MB, you would need a new video card with more memory in order to run the program. Thanks for rating FixYa!
Jan 07, 2008 | Microsoft Office Standard for PC
Pc cd-rom
Unfortunately, you'll have to get a better video card if you want to play the game.
This person (2nd down) had the same problem:
http://www.amazon.com/Paws-Claws-Pet-Vet-Healing/dp/B000PWTKG8
Dec 26, 2007 | Audio Players & Recorders
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
