Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
Detergent door does not open during wash cycle to release soap
  • Bosch Master
  • 43,501 Answers
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " Great tips, will get the handy husband on this asap........thanks " -
Posted on Apr 27, 2010
2 Suggested Answers
Soap running down side of door
Are you using a ultra low suds laundry detergent? If not do so.
Jun 27, 2017 | Dishwashers
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispenser door does not open during wash cycle. it can be opened with the manual release.
close the soap door and put into diagnostics. most models you can do so by pushing heated dry-normal-heated dry-normal. let it do its test and if the soap door opens during the test cycle, most likely the soap door assembly needs to be changed.
Nov 17, 2009 | Whirlpool Dishwashers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Small door where soap goes does not open during cycle.
Most detergent cups are spring loaded and released by either a mechanical trip or by a bi-metal strip latch. If your model is a simple dial timer type, look for a mechanical linkage between the timer and detergent cover. If it is a touch panel control, look for the other type. The bi-metal strip type has a heating wire wraped around it that can open electrically or burn out physically.
Mechanical types can be checked by rotating the timer knob 360 degrees while watching the detergent cover linkage. Electrical types require use of an ohm meter to check the resistance of the heating element on the bi-metal strip.
If you are using powder type detergent, make sure it is not caked when added to the cup or it can jam the rotating type covers.
Feb 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 16163 401 dishwasher
The dispenser flap should be spring loaded to spring open if the lock is released. If it doesn't spring open you should make sure that the spring is placed correctly on the hinge of the flap - if it doesn't spring open it won't get the detergent where it needs to go during the wash. We had the same thing.
Dec 17, 2008 | Kenmore 24 in. 16163 Built-in Dishwasher
Main Detergent Dispenser does not open during cycle
check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
69 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
