Question about Kenmore 24032\24036 Top Load Washer
Washing machine is not adding water in the middle of cycle
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has a troubleshooting section as well as testing procedures.
The problem points to a couple of places. Either the TIMER (unlikely) or the Water Inlet Valve, Temperature Switch or Level Switch.
See the following for how to access the console and pull the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
Posted on Apr 26, 2010
  • 641 Answers
SOURCE: Maytag Washing Machine
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Sep 06, 2007
  • 209 Answers
SOURCE: my washing machine is full of water!!!
check pump for open circuit electrically, if that is fine and the pump works but just doesn't drain then its a blockage somewhere between the drum and the waste outlet, strip the pipes and clean out, taking care to note original position of any parts and wires etc
Posted on Oct 14, 2007
IFIXALL
  • 868 Answers
SOURCE: Samsung washing machine won't complete cycle
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
Posted on Jul 13, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
  • 11 Answers
SOURCE: Machine stopped in middle of wash cycle.
Timer needs replaced try gigling your timer knob and see if you get any reaction dont be afraid gigle it up and down hard sounds like point in timer are burnt
Posted on Sep 17, 2008
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Washing machine sticking in middle of rinse and spin part of cycle
If your machine is stopping at the rise cycle, then you have a faulty cold water inlet valve/solenoid.
To verify this, turn off your hot water tap and only leave the cold water on. Put your machine on a cold water cycle. If the machine does not fill up, it means the valve/solenoide needs to be replaced.
Also note if you had water left in the tank prior to rise cycle commencing, then the drain pump is blocked.
Ash
Sep 11, 2011 | Hotpoint Washing Machines
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Machine stops in the middle of the cycle. I had only a robe and pair of pajamas in the tub and water level set at medium. I moved it to "spin cycle" to get the water out of clothes, but nothing...
Same problem as yours. The GE repair man is at our house right now for this problem. It's the motor, and the "special motor and clutch package" has to be specially ordered.
Jan 04, 2011 | GE Profile WPRE8100G
Would you know why a washing machine stop in the
How much soap are you using? These newer models only use a small amount of water. You go adding a ton of detergent and that washer is gonna worry itself to death trying to get rid of excessive suds.
Jul 06, 2010 | Westinghouse Washing Machines
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
In the middle of a cycle, it has stopped and is
nf is NO fill
i would check your cold water line
take it off the machine and check the screen as well
no fill means it is timming out waiting for water
Oct 09, 2009 | Samsung WF337AA Front Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
