Question about Canon PowerShot S50 Digital Camera
Flash use "kills battery dead"
I have a many year old S50. I use it primarily in manual exposure mode. Recently the flash has been draining the battery and today the flash has stopped working all together. When I attempt to take a picture with flash it shuts off and tells me the battery is dead. I remove the battery, replace it and all functions normal, but still no flash.
Everything else works fine.
  • eplayer Jul 21, 2008
    I have the exact same problem. I cannot take any shots which require flash. A fully charged battery is exhausted within 5 minutes. If I even attempt taking pictures on the AUTO setting I can hear a little clicking when I press the shutter button, but no flash and no picture. I can change the dial to other settings and take a pictures, but with no flash assistance.
    I receive a message on the LCD screen stating "change batteries".
    I purchased a new battery from Best Buy, fully charged the battery and inserted in to the battery compartment, but the exact same thing happened. No pictures could be taken requiring the flash and again the battery is exhausted in approx 5 to 7 minutes.
    Can you help?
    President:
  • 423 Answers
The most likely culprit is a several year old battery that is not accepting or holding a sufficient charge. Turning the camera on, and taking a non-flash photo may not tax the battery too much. However, when the flash is called for, the power demand may exceed the battery's ability to deliver enough juice. A new(er) battery is probably your best bet to resolve the problem.
Posted on Mar 24, 2008
Can i use my vivitar 4600 with my nikon d300s?
Yes. You can use the flash in auto or manual mode by setting the camera to manual shutter speed within the x-sync range and then selecting the aperture prescribed by the flash guide number or the displayed automatic f-stop on the flash. The flash can provide auto exposure with the camera in manual mode, but you need to be aware of the amount of ambient light which will not cause any exposure corrections by the camera in this mode. Another alternative is to select Aperture preferred automatic on the camera and the f-stop shown for the auto flash settings. This will allow the camera to vary the shutter speed but may cause long exposures if the camera is not sensitive to real-time flash readings.
May 05, 2014 | Vivitar Cameras
When i press flash icon the display says "not available in these settings"
The flash is not available in certain exposure modes. The camera decides whether to use the flash in Auto mode, and the flash cannot be used in Landscape mode, for two examples.
Try switching the camera to the Manual exposure mode. Can you use the flash then?
Apr 13, 2014 | Nikon D3000 Digital Camera
I have a Sony Cyber-shot Super Steady Shot DSC-T10. I have 2 babies under 2 years old and every time they are doing something adorable I can't get the shot because my delay on my camera is so long they are...
It seems the Red-eye reduction feature of the flash is ON. In this mode, the camera emits a pre-flash and then the actual flash discharges after a delay. Or it could be on Slow Sync. In this, the flash fires at the end of the exposure. Just go to Flash modes (the lightning-like icon) and if it is showing an eye-like icon or the word 'slow', change it to some other mode, probably the flash ON or OFF mode. Also, make sure that the batteries are fully charged.
If this solves the issue, please rate this solution.
Sep 02, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Recently my canon speedlight 580 EX II TTL has been acting up...especially in low light situations. About on in 30 shots actually has enough light in them...the rest of the time the shots are...
that the camera/flash set-up I use ... there are many variables - iso/metering setting/shutter settings/flash settings .
If it's a flash function problem, try this to isolate it - first, with the diffuser/reflectors tucked into the flash head, and the head straight up, with the flash set in master mode, turn it on and look on the back screen. push the mode button til you see the ETTL in the upper left of the screen .. then press the set button in the center of the dial and the nuber in the center of the display should flash (+0) while the light is flashing, rotate the dial to change the setting (i usually under power by 1/3 stop. Play with the exposures a few times to get the feel for what the EV shifts do to your exposure. generally speaking, for interior low-light, i prefer to bounce off the ceiling (if low ceilinged), if there's too much direct it will give you an uneven and predominantly underexposed image.
if you prees the mode button you will come to the same options for adjusting the output in manual mode, but it will not work with the autoexposure in the camera.
Try playing with the ETTL settings
I think the problem may be that you have somehow altered the power output setting on the 580.
Sep 23, 2009 | Canon Speedlite 580EX II TTL Flash
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
Dell 600m Laptop Killing batteries
If you are using known good batteries, and you have the most current BIOS Flash, then it is likely a failure of the charging curcuit on the motherboard. The flashing Amber (Some people see it as red) led indicates a failed battery
The Multiple good batteries, I assume have been recently purchased, because computer batteries are consumable and are rated for 300 to 500 charging cycles before they wear out.
I replaced my 700m motherboard with one from Ebay for about $170.00 about a year ago.
Jul 05, 2008 | Dell Inspiron 600M Notebook
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
The ADI flash metering mode combines distance information from the auto focusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, and 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
My exposures come out inconsistent
You cannot use the E-10/20N in Program Mode with studio strobes. Studio strobes are not compatible with TTL (Through The Lens) metering. You will need to set the Mode Dial to Manual Mode. Exposure is determined by flash output , ISO and the distance from flash to subject. Proper exposure can be determined with a flash meter.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Canon PowerShot S50 Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
