Question about Microsoft LifeCam NX-6000 Webcam
The program just stopped working! Help! It won't open at all.
    Scholar:
  • 202 Answers
First go to Control Panel, hardware, Devices and look for your webcam. Go through the tabs to make sure it is Enabled. If you don't see your webcam, or you can't click enable, then you will need to reload the software drivers, either from disc or the manufacturer's website. Once you think you have it working you may want to reboot your computer, and then try the free webcam test tool.
Posted on May 07, 2010
Newly installed garage door opener won't go up completely
check that none of the springs are broken. can you manually push it up the rest of the way?
Feb 09, 2013 | Craftsman 3/4 Hp Garage Door Opener System...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
How do i use this program if it won't open right?
Do you REALLY want to use it? From reading other people's comments about it here on FixYa, that program is more trouble than it's worth. I would seriously consider using a much better program such as Picasa, which also does not lock me into a specific camera brand.
Jul 13, 2012 | Cameras
Bubble Shooter won't run
ok open the start button
control panel
system icon
tell us what the memory and cpu and number of bits(32 or 64) that this panel reports
May 30, 2012 | Computers & Internet
Been using safari for a while and now its just stopped working won't open at all
It is possible that your computer may have shut down unexpectedly e.g. from a power cut or the battery dieing and so the program did not close correctly. When this happens the settings file may sometimes become corrupted and so the browser stops working. To fix this you have to download the installer for safari through another internet browser or from another computer and reinstall it over the old copy.
Oct 18, 2011 | Acer Computers & Internet
My Nikon Capture NX2 has stopped working, tried to open it last night and Windows said it has stopping working and will close the program, nothing new to computer just stopped working. I have...
Does your PC recognise the fact that you've connected your camera?
Try uninstalling Capture NX2 and then reinstalling, if you still have the Installation CDs.
Jan 12, 2018 | Nikon Capture NX 2 Full Version for PC,...
Hi,my wife lives in china and we talk thru yahoo messenger mine works just find but hers won`t open yahoo email will open but not the messenger HELP thanks oldtenbears
Make sure she downloaded all the software for the program..Go to yahoo and download the messanger program..Hope this helps,,Darren
Oct 10, 2009 | Yahoo Messenger
Liftmaster Professional and Clicker Programming Problems
The Security+ system is a rolling code system and is digital, so it will work with the Homelink in vehicles and with the remote control units that come with the opener. Also with new remotes that are purchased specifically for that opener. Your "clickers" require specific instructions and you need to use the Smart Learn function in order to use them with this opener. In addition, check the Brand Switch settings to be sure they apply to your opener, and the correct Smart Button color on the opener. Read carefully to determine whether you need to set ANY dip switches at all or can you just set them all to off depending on your opener? Check the instructions carefully. Here's a link to the page where you can download a copy of the Clicker instructions if you don't already have it:
. Clicker Model CLT1D Remote Control Owner Manual
May 14, 2009 | liftmaster Chamberlain Garage Door Opener...
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Microsoft LifeCam NX-6000 Webcam Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
