Question about Panasonic CT-32SL14 32" TV
Program Panasonic remote to control cable box
I have Panasonic remote control EUR7613Z6A and I need to use it to control my Comcast cable box DCT700/US made by Motorola.
  • 6 Answers
SOURCE: Need 5 Digit Remote Code for a Panasonic Receiver HE-100
Try 1518 or 1039
/www.comcast.com/remotes/universal.html
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Posted on Dec 30, 2008
SOURCE: Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
Posted on Jan 14, 2009
  • 267 Answers
SOURCE: Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Posted on Mar 06, 2009
AmerIHCan
  • 14 Answers
SOURCE: need panasonic tv remote code to program my
model number of your emote should be under the battery lid. Search google for
universal remote codes your_model_remote
Remote should come with a sheet containing the codes. If yours is not on there, contact the 800 number for the remote manufacturer.
HTH
Posted on Apr 24, 2010
How do I download a quick guide start up manual?Pan
All cable company's have a remote that can also control your TV. Flip your cable remote over and find the part number on it. On rare occasions, it might be inside the battery department instead of the back. Type that part number into your internet browser with the words guide or manual and you should find the manual u need to program your TV into your cable remote. If all else fails, call your cable provider.
Feb 16, 2015 | Panasonic Viera TH-42PZ80U Plasma TV
HOW DO I PROGRAM MY XFINITY COMCAST REMOTE
Check here for a list of manufacturer codes for your specific remote: Comcast Cable Remote Support
Check here for a video of how to get into programming mode: Program Your Comcast Remote
Comcast's remote page seems to be broken right now, but may work in the future: Comcast Remote Codes Program Your Comcast Remote Control
Please post back if these don't help!
Dec 23, 2014 | Samsung UN46D8000 46" 1080p 240Hz LED 3D...
How do i program my comcast remote to my panasonic home theater system? SA-HT740 series
I have the solution! Get comcast to give you the remote with the GREY Ok/Select button. There are codes for this remote that support the Panasonic home theatre in a box. You can go to comcast.com and find the remote manual for this to see it for yourself. I have 3 boxes and just got a new one and was trying to do the same as you. I found the old remote for one of my older cable boxes and switched it out, programmed for the Panasonic and it all works quite well!
Nov 15, 2010 | Panasonic Home Theater System System
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Unable to tune in generic remote control
I have the code book for this remote.  I am having difficultly with my Sharp CD player.
Codes for panasonic tv 0011,0024,0032,0106,0118,0131,0139,0212,1083,1140
codes for pioneer dvd
5008
hoped this helped someone
Dec 29, 2007 | Universal Remote Control Remote Control
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Panasonic CT-32SL14 32" TV Logo
682 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
