Question about Eclipse AVN5435 Car DVD Player
Need to know which wire is the hand brake wire
  • blingbling81 May 11, 2010
    is there a green and white or purple and white? what colors do you have
  • 93 Answers
Its the pink wire.
Posted on Apr 27, 2010
Right hand brake light not working vp commodore.bulb has been replaced but still no go
I assume the left hand brake light works.
First check that you have replaced it with the correct bulb. Make sure it is the same as the left hand brake light bulb.
Sounds silly but different bulbs will fit the same socket, but not work.
Make sure no one will push the brake pedal and see that contacts are clean and there is spring pressure behind the contact in the socket. If all the above is okay then you probably have a wiring problem.
Either the earth wire, usually black, is damaged or not connected to earth (body work) .
Or the power wire from left hand side light is cut or damaged. Check the colour of the wire on the left hand brake light. It will be the same for the right side.
If you have a trailer plug follow the wire from it back to where it connects to the cars original wiring. The problem could be at that connection.
Good luck
Feb 17, 2013 | Cars & Trucks
Parking brake light comes on when brake not on
Usually this indicates that either the cable is bad, or the rear brakes are not adjusted up so this makes the pedal sit too low on the parking brake (or the hand lever sits too high).
Jul 21, 2010 | 1997 Oldsmobile Eighty Eight
How to connect hand brake cable on meos MC701B
if you can get to the hand brake, there is usually 1 wire coming off of it at the base, you will want to test it to make sure it is sending the ground pulse, just splice it into that wire. If you want to save yourself the headache, just put a switch to a ground (-) and hook that up to the handbrake wire (coming from the unit). It will do the exact same thing, but with a lot less work.
Apr 29, 2010 | Car Audio & Video
What can i do to wacht dvds?
you must have connected the safety feature to the hand brake.
this disconnects the dvd from working until the hand brake is applied. you will need to attatch this wire to a ground connection to enable it to be played while moving
Apr 06, 2010 | XO Vision GX1046 10.4 in. Car Monitor
Replaced brake swith brake lights still not working
hi, due to the age i would remove the back lights and have a good look at the circuit that all the light bulbs plug into you may find that you have loads of corrosion remove this using sand/glass paper also check the connectors for the wires going to the back lights and also check the earth wire for the back lights if you remove the back lights you will see what i mean.
have you also tried pressing the brake light switch before you fitted it to the brake pedal you should have turned your ignition on and then pressed the button in with your hand before fitting to ensure this is the problem doing this then lets you know if the brake pedal is bent or the switch not fitted properly so you could remove the switch and try operating it by hand if it works this way you can then put tape around the brake pedal to build up the part that presses the brake pedal.
Let me know how you get on or if you need further assistance ok
Mar 10, 2010 | 1983 Jeep CJ5
Emergency brake light stays on brakes ok fluids ok
2 issue may cause the light to stay on. 1st, the brake resevior switch in faulty, the cap with two wires attached to it. Secondly, the emergency brake switch is faulty causing the light to stay on. to replace the switch. Both are cheap and very easy to replace and fix.
Nov 23, 2009 | Pontiac Sunfire Cars & Trucks
95 road king brake light does not work taillight works changed
I take it it does not work foot or hand control. look for your brake light switch right side of frame rail usually a goldish color or silver color. it has two plug in connectors. Unplug and put a test light to them. apply either brake. If the light comes on then you have a bad brake switch. replace it. if you have foot brake and no hand brake light then it would most likely be the brake nipple in the hand switch. but you did not say so I assume no brakes foot or hand.
Jun 09, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Alpine IXA-W404 how do i can't get video to play. I didn't connect the hand brake wire and the footbrake wire, would that be the cause and if so how do I get past it??
You need to connect the yellow/black wire to the brake switch and the yellow/blue wire to the ground wire on the hand brake. After that you have to go through the task of holding down the foot brake, pull the hand brake, release the hand brake, pull the hand brand then release the foot brake.
after all that then you can watch your video. You will want to connect those wires so you can setup your system.
Jun 07, 2009 | Alpine Car Audio & Video
I need to wire a towbar to my lt 28 but have no wiring info
Trailer socket pin1 (yellow) to left hand indicator (Black/White) at L/H Lamp, Pin2 (blue) to fog (Grey/White) at R/H Lamp, Pin3 (white) to Chassis Earth, Pin4 (green) to right hand indicator (Black/Green) at R/H Lamp, Pin5 (brown) to right hand side light (Grey/Red) at R/H Lamp, Pin6 (red) to brake (Black/Red) at either Rear Lamp, and finally Pin7 (black) to left hand side light (Grey/Black) at L/H Lamp.
Mar 25, 2009 | 2004 Volkswagen Eurovan
Eonon E686 DVD player will not show picture on the screen, only sound
You need to connect one wire to hand brake, to make ground, otherwise you can't wach while driving. or just connect hand brake leed to negative.
Aug 11, 2008 | Televison & Video
Eclipse AVN5435 Car DVD Player Logo
118 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
