Question about EliteGroup L7VMM2 Motherboard
Overclocking Im tryin to overclock my pc, and i want to increase the speed for my vidoe card but dont know where to go
    Master:
    Sergeant:
  • 482 Answers
I would only upgrade the memory in your computer.
Posted on Mar 23, 2008
Overclocking aopenax4b-533 mobo
In some motherboards, you can increase the multiplier, which will increase your processor speed.(Briefly, Processor Speed = FSB x Multiplier) You can also increase the chipset, memory, and CPU voltage, which will sometimes allow you to have a higher FSB. There are other settings such as PCI Bus and AGP Bus, you generally don't want to touch those, either they might put risk to your PC, or that they won't make much difference in performance. Be careful when you overclock because you can really damage your computer that way.
Mar 08, 2010 | AOpen Computers & Internet
Overclock fan speed question
The amount that you can overclock you're video card differes for each individual card. The limiting factors are temperatures and stability. If games start crashing, etc you should back off the overclocking. Also keep in mind the temperature of the card. Increasing fan speeds will lower the temperatures of the card. Increasing the fan speed (as long as you don't go beyond 100%) will not damage the card... It will be louder though. For the 9800gt, the maximum temperature before damage is 105 degrees C. Try to keep the temperatures at 80 or below optimally. Increasing the fan speed is the best way to accomplish this.
Jan 17, 2010 | Nvidia Zotac GeForce 9800GT Amp Edition...
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
Overclocking
overclocking is a risky processor which increases cpu speed . i causes cpu burn out causing damage to mother board . if ur computer is in warranty time then ur warrnty might be get cancelled and can cause serious money loss
Dec 23, 2007 | Computers & Internet
OVERCLOCKING
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
How can I overclock my 166mhz classic computer?
Overclocking is not really recommended to be done by normal users. For overclocking your computer, you should have extensive knowledge of the hardware of your computer.
Overclocking may result in a totally non-working computer, burnt up Processor and motherboard and the likes. Also, overclocking results in heating problems, so you need to have made the arrangements for taking care of this heat issue.
Basically overclocking means increasing the Clock Speed of your comuter. Suppose I say that I have a Pentium 4 - 2.4GHz computer, the 2.4GHz part is the clock speed, which is increase in overclocking. Surely the computers with higher clock speeds work faster but that comes at a price. A small mistake on your part and your computer is no more working.
There are various Forums and sites on the internet that discuss Overclocking and its intricacies in greater detail.
Here's a pointer:
http://www.extremeoverclocking.com/
PS: Search google for "overclocking" and you should get a lotta links to work with.
Oct 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Anyone experience problems with an overclock E-125?
There are some overclocking programs available like through www.jimmysoftware.com or even hardware fixes. The one by jimmysoftware is for the iPAQ only. iPAQ Overclocking software I would strongely avoid doing the hardware fix. The overclocking applies only to the processor itself and does not take into account the I/O from the the processor to the various other hadrware components. Some games, video, and apps may perform better but anything hardware related like PC card or CF cards that have a function like modem, networking etc. . . can run into timing related issues and not function. At least the software version can be easily removed. Good luck
Sep 04, 2005 | Casio Cassiopeia E-125 Pocket PC
EliteGroup L7VMM2 Motherboard Logo
42 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
