Question about Gaggenau GI936-760 Dishwasher
An "F" has appeared on the alphanumeric display
I turned on the dishwasher (Gaggenau Model GI936-760, purchased in 2002) as usual. Two hours later I noticed that the motor was still running. When I opened it I found that the alphanumeric display showed "F" (this "F" is not mentioned anywhere in the manual) and the soap dispenser hadn't opened. The dishes were dry - no water had entered the dishwasher - and dirty.
What's happened? How do I fix it?
  • threeeeee Apr 26, 2010
    Assuming you can read my original question and the reply, I need information that is specific to the problem with the Gaggenau GI 936-760 and what the "F" in the alphanumeric display means. The advice I received earlier did not apply. I did not press the "off" button and there's nothing in the manual that tells me how to solve this problem. The links sent by the last expert did not apply. In the meantime, I have tried pouring water directly into the filter on the floor of the machine. The pump got rid of that water, but then nothing happened. I also turned off the circuit breaker that runs the dishwasher and turned it back on. The "F" still appeared. Thank you.
  • Gaggenau Master
  • 19,396 Answers
The F must be followed by a number. F alone it is not an error code, but it looks rather like the symptom of a faulty timer control board.
Try first tripping the circuit breaker or disconnecting power cord for five minutes ande see if this can reset the error.
If it does not , then it is probably a defective timer board. In that case call Gaggenau at the number listed on the user manual, they will ensure that there is a fault and provide you with the replacement part.
Regards.
Posted on Apr 26, 2010
  • 12,061 Answers
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136348
Breakdown diagram above, above that are some DIY for dishwashers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Above is the service manual, this is what us engineers use, to service and repair.
It maybe that something has tangled up in the timing department. Please use the manual to isolate your problem with the troubleshooting guide.
Now tgis below, may or May not apply to your situation, however it is amazing the machines that respond to this "Fix" so it may well be worth a try, to start. Also. First.try simply unplugging from the Wall and leaving disconnected for 5 mins or so, plug it back in, often this clears any fault. Otherwise you will need to troubleshoot, or call a professional. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
How do you "reset" a Gaggenau dishwasher model GI240760/01 when it does not turn on via the touch pad?
then I would call the same place again . writing down the instructions this time .
Jun 08, 2016 | Gaggenau Dishwashers
Is there a reset?
Depress the on/off button, then depress at the same time the SCRUB WASH button and the DELICATE/ECONOMY buttons at the same and hold for approximately 3 seconds. You will see the alphanumeric display progressto end. When the drain pump has stopped and the alphanumeric display is at the end, the cycle is complete and the the dishwasher is reset.
Jul 28, 2009 | Bosch SHU5316UC Dishwasher
Older Gaggenau double oven unit...heating elements stop working
Shut off te breaker for the oven for an hour then turn on again and it should come back on, just so you know Gaggenau appliances are super high end, if it needs service it will cost you
Jul 10, 2009 | Gaggenau Ovens
Gaggenau dishwasher model GM- 915-710
i suspect you are hearing the drain pump working due to the antoflood being actuated.
remove the bottom front panel and bottom tray is exposed and it is probably full of water. mop water out and machine will work. if fault reoccurs, then you have a leak
Oct 01, 2008 | Gaggenau GI936-760 Dishwasher
Gaggenau dishwasher keeps running
press the intensive and crystal buttons @ the same time, the display will change to 0. Close the door the pump will run for a while when the pump stops the dishwasher is reset.
May 26, 2008 | Gaggenau GI936-760 Dishwasher
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
F message n Gaggenau 936-760
Prime the dishwasher by pouring a large glass of water into the filters on the floor of the dishwasher. Then close and run the dishwasher as usual.
Nov 23, 2007 | Gaggenau GI936-760 Dishwasher
Gaggenau GI 936-760 dishwasher
Buy a new one and sell me the door. I have been looking for this model's door for a long time!
williamduck@comcast.net
Aug 02, 2007 | Gaggenau GI936-760 Dishwasher
Gaggenau GI936-760 Dishwasher Logo
104 people viewed this question
Top Gaggenau Dishwashers Experts
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
