Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Where do i purchase a replacement lcd for a canon powershot sd400
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
You may order the part from here.
Posted on Nov 09, 2012
jbreth
  • 69 Answers
SOURCE: as a webcam
No I am afraid you cannot use this as a web cam. I have asked Canon about this and they said that it isn't capable. Sorry
Posted on Aug 26, 2007
jerryg50
  • 1667 Answers
SOURCE: broken lcd screen on my
Send the camera to the Canon service rep if you want to have this fixed. Ask for an estimate before approving the service.
Jerry G.
Posted on Jul 14, 2008
kenshin99
  • 89 Answers
SOURCE: Hi. My Canon Powershot sd400
Hi!
You have to unlock your memory card. All memory cards have this small lock mechanism on the side.
Make sure that the slider is on the UNLOCK position. If it's already on the UNLOCK position and you are still getting the same error message, try to set it to LOCK, then set it back to UNLOCK position.
I hope that helps.
Good luck and have a nice day!
Posted on Nov 26, 2008
  • 7 Answers
SOURCE: I bought a 4g SDHC card for my camera canon powershot sd400.
Well, first of all, I'm not exactly an expert on this, so please don't rely solely on my response.
It's possible that it needs an SD card, not an SDHC card. SDHC cards are high capacity, and some cameras just aren't able to use them because they're set up for the plain SD cards. Does it say what kind it needs in the manual? I think, if it's an older camera, I'm not sure what age exactly, they can't use SDHCs. Like I said, I'm not an expert, so you might want to get more info, if you can. Hope this helps.
Posted on Feb 16, 2009
kram26
  • 544 Answers
SOURCE: how to repair lcd screen canon powershot sx110-is
hi,
For that camera that died, here are some non-intrusive simple fixes that you should try before throwing in the towel. Copied this first post from somewhere. It was a fix for a Canon A520, but am not sure if it would work for other cameras with the same problem? For those of you with a camera that will not power up or turn on, especially if this occurred after a power interruption with your lens extended, please give it a try. If you do, please leave a comment on specifics like your camera make/model, and whether it worked for you or not.
"DEAD CAMERA, LENS OPEN-If the batteries run down completely while the camera is still open, it may not start up again when new batteries are installed. But if you remove the memory card, then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time."
OK, so the above didn't work. Next thing to look at are the batteries themselves. Are you using alkaline batteries, or worse yet those "Super Heavy Duty" batteries? If so, betcha we've just discovered your problem. Alkaline and regular "super heavy duty" batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. It doesn't matter if they're new, and right out of the package. Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said). Most retailers sell NiMH batteries for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
OK, so maybe those newfangled batteries didn't fix your camera, don't give up just yet. The next thing to check is that your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.
The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. Am planning on posting sometime in the future some likely things to check, hopefully with a pictoral guide. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
As before, if one of these simple fixes worked in your particular case, please leave a comment on your camera's make, and which fix worked.
Good Luck!
Camera Repair please don't forget to rate our answers..
Posted on Feb 19, 2009
CANON POWERSHOT SD400 5.0 MEGAPIXEL DIGITAL CAMERA. CAMERA POWERS ON BUT THE LCD SCREEN REMAINS BLACK
if there is image formation u will find image on the lcd,defect with the formation,so CCD and shutter must be chaqued.
Mar 06, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
No image preview
You would need to buy a new lcd for this would be the obvious soltuon in this case. Do not shoot the messanger!
May 25, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Delete photos
The Canon PowerShot SD400 has no internal memory. All pictures are recorded on a memory card.
Aug 27, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
SD400 LCD screen only HALF works
Hi, press the Display button 2 times to turn on the LCD display.
thank you
Aug 19, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Cannon sd400 power shot
Sounds to me like you have a broken LCD screen. This is unfortunately very common in the SD200, SD300, and SD400 cameras. Because an LCD display is made up of a few sheets of very thin glass, they tend to break rather easil and then the "dye" leaks out, hence your feather pattern.
If you feel up to taking your camera apart, you can purchase a replacement screen on eBay for around $60-$80. If you don't feel up to trying to replace it yourself there are people on eBay who offer repair services for broken LCDs and they typically charge between $80-$100.
Apr 10, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon SD400 LCD screen does not work
The symptoms you describe sound like a CCD failure. Canon is fixing this for for free for certain cameras, including free shipping both ways. This is regardless of the camera's warranty status. However, the SD400 is not on the advisory list (although the S400 is). Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 15, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
LCD Screen Color is Washed Out and Blue
Hey i found this site that is great on how to change a LCD for the camera
http://digitalcamerarepair.googlepages.com
Sep 25, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon IXUS 50 Digital Camera LCD not working
I beleive (this is only from my memory) their are 2 different LCD for this camera, sounds like you got the wrong one from canon, need to be sure its the same part number as your old one
Sep 03, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon powershot sd400 camera problem
you can get a manual on E-bay this will help you find the fuses
Aug 29, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
