Question about Bosch Classixx KGV24323 Bottom Freezer Refrigerator
Hi , fridge seems to have no air flow- smeels -it
Hi , fridge seems to have no air flow- has odours -it is new -did we set it up right ? it is a Bosch unside down fridge- could the air flow be blocked- it seems to be airless.
4 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: My Bosch Fridge Freezer Model
Hi thanks for the question. I would pull fridge away from the wall . remove back panel . clean all coils . thanks the appliance doc
Posted on Oct 06, 2008
  • 1462 Answers
SOURCE: FRIDGE NOT VERY COLD - ABOUT 15 DEG C, FREEZER OK
relies on air flow between fridge and freezer but is regulated.
fault is probably ice build up on top of evaporator in freezer. remove back panel inside freezer and check. also check the air ducts are not iced up
Posted on Nov 20, 2008
  • 38 Answers
SOURCE: we have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Posted on Mar 14, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Bosch Classixx Fridge freezer KGU30604 I keep finding water in the bottom of the fridge but whenever I clear it, it reappears. Both fridge and freezer appear to be working otherwise. The fridge is set to ...
Hi Kloynes,
It could be a problem of LEAKAGE.....Followings steps may help you tackle the problem:
Steps
  1. Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
  2. Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Tips
  • Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
Warnings
  • Use caution with anti-bacterial products. Make sure that any such products cannot flow back into the food compartment.
Things You'll Need
  • Wire hanger
  • Anti-microbial agent such as chlorine bleach, rubbing alcohol or anti-bacterial soap.
Thanks
Sep 03, 2008 | Bosch Refrigerators
Hotpoint rla31 motor constantly running/freezing at the back
Your fridge is cooled by the freezer, the thermostat is within the Fridge to tell it to shut off, you might have a bad fan or a build up of frost where the air is sent to the fridge, check where air goes to the fridge when it's running, if you don't feel air flow then something is up, best thing you can do is take everything out and allow the fridge to defrost, at leat 24hrs. then see what happens, if you don't feel air flow after the defrost then you fan is shot and you'll need to replace it.
Aug 04, 2012 | Hotpoint RLA31 Compact Refrigerator
The fridge is producing a bad odour from some
The odor is coming from the defrost liquid Throw it away and clean the interior of the refrigerator with detergent and remove moisture. Dry it by opening the door for about 3 or 4 hours and then set the
temperature control button at strong.
Oct 26, 2009 | LG Refrigerators
Suspected broken fan prevents top fridge section cooling down
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Jul 29, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Nov 19, 2008 | Bosch Refrigerators
We have a 2-years old Bosch fridge. KSU40. Now we frequently have water under the door. I seems to come from the inner back of the fridge. What is the problem.
on the back wall at the bottom, there is a gulley with a drain hole in the middle. this drain is blocked. push something flexible down to clear the blockage and make sure water flows away freely
Oct 05, 2008 | Bosch Refrigerators
I have a fridge freezer (can't remember exact model) however we seem to get a small puddle of water at the bottom of the fridge section (front left as you look at it to be precise) although the fridge...
check if there is a gulley on the back wall of the fridge with a drain hole in the middle. if so, this drain may be blocked. poke something flexible down the drain till water flows away freely
Sep 17, 2008 | Bosch Refrigerators
Bosch Classixx KGV24323 Bottom Freezer Refrigerator Logo
60 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
