Question about Whirlpool WFW8300SW
F 28 message
I start my machine and i get an f-28 message and it stops and does nothing
    Scholar:
  • 126 Answers
Your motor control board has probably failed in the bootom of the machine.
Posted on Apr 26, 2010
Empty Developer on MP1900
Should replace the TYPE 28 DEVELOPER every 60,000 pages.... this is needed to mix with the toner. if you cleaned the toner/ developer mix out of the developer already then it will definatly give you blank pages ..... hopefully this helps.
Mar 13, 2014 | Ricoh Office Equipment & Supplies
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Starts cycle then stops and displays F-28 and F-29 codes wont spin or get all water out of clothes
ok the f-28 means on of these parts are bad,, motor control unit or microcomputer control unit,,, f-29 is the door lock i would start with the microcomputer control unit,, but i always replace both parts at once saves alot of time waiting
Jan 22, 2011 | Kenmore HE2 Plus Front Load Washer
The washing machine seems fine but will not start the spin cycle
Hello there, I got a whirlpool sport washer machine that is showing off code f-28 and it gets the door locked! I have unplugged it and have taken the toe kick plate to reach for the release lock. I select a cycle but it seems to send signals to the motor, inlet valves but it just stops and nothing happens,. so if you could help me I would really appreciate it! thanks joe
Sep 04, 2010 | Whirlpool Washing Machines
My DC16 will start and then stop. I have to take
My DC16 also had charging problems. I called Dyson and they sent a new charger. The old charger only produced 23.6 volts DC, not the rated 28 volts DC. The new charger has a thicker round wire and produces 28.1 volts DC. Put a volt meter on your charger terminals and see if it is producing enough voltage to fully charge the battery, 28 volt DC. If not you need a new charger.
Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Kenmore F-28 error - door locked can't get in
Unplug the machine.
Wait 15 seconds.
Plug machine back in.
Press and hold the Power button until the lights come on.
Press and hold Start.
When you hear a click, press Stop.
Open door.
You still have an F-28 issue but you can at least get your clothes now.
Hope this helps.
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Kenmore Elite HE5t Power and Errors
try hitting pause/cancel twice to clear the codes
May 17, 2008 | Kenmore Elite 45986 Front Load Washer
Machine stopping
Whenever mine does that, I just press start (the green or red button) on the machine again and mine usually starts back up.
Jun 26, 2007 | Singer CE-100 Futura Computerized Sewing...
Whirlpool WFW8300SW Logo
171 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
