Question about Sony KP-57WS500 57" Rear Projection Television
Blue color is causing a miror effect
There is a blue haze caousing all the words on the TV to have double inamges and there is a yellow or blue halo around some images.
  • Sony Master
  • 8,457 Answers
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Posted on Apr 26, 2010
Yellow Shading.
go into the menu for the color or brightness and contrast..try to change a bit at a time..
Jan 08, 2014 | Samsung LN52A550 LCD TV
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I was given a tv with a color problem. The main colors are yellow, blue and red. There are blue shadows behind the yellow words. Is this a major problem?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Hitachi 46BX01B 46" Rear Projection...
Tv shows double vision in blue color. how to fix this problem?
This is a problem with your convergence settings found under your tv's menu. its very easily fixed, you just need to open the setting for convergence and use the arrows on your remote to adjust. inproper convergence can cause either a red or blue haze around almost any object displayed on the tv screen
Apr 14, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Yellow haze
Hi...the yellow haze is probably the blue filter is burnt and needs replaced. This is very common in Zeniths. There are 3 color filters in the Zeniths blue (pinkish in color), green (grayish in color) and the red (it is red). The #1 problem in this TV is the blue filter is burnt and it is an easy fix. It could also be the LCD cube is bad. I would try the blue filter replacement first. It will probably do the trick.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow corners on 56" RCA Rear Projection TV
possibly cleaning of the lens and the mirror might improve the picture. it could be what is termed a glycol or fliuid issue. dirty glycol will cause this yellow halo effect. the glycol came be changed a rather expensive and evovled repair i think
Jan 15, 2008 | RCA P46810LV 46" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
79 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
