Question about Microsoft Windows Vista Ultimate Edition
Block icon from appearing in system tray - Microsoft Windows Vista Ultimate Edition
  • 63 Answers
Due to fack licence ur window has been corrupted
Posted on Apr 26, 2010
How to turn off ringer at particular extension?
Do Not Disturb (DND)
When DND is enabled, the telephone will not ring when someone calls, but the line
indicator still flashes. In Personal Call Manager, the
You Have a New Call dialog box
still appears and the icon for the call appears in the Calls box.
You can turn the Do Not Disturb (DND) feature on or off from the
Calls menu or the Personal Call Manager icon in the task tray.
Turning DND on or off
To turn DND on or off:
1. Click the Personal Call Manager task tray icon or the
Calls menu.
2. Click the DND menu item.
When DND is on:
• the Personal Call Manager task tray icon changes to
• the symbol check
appears beside the DND menu item on the Calls menu and the
Personal Call Manager task tray menu
• DND appears in Status bar
Oct 23, 2013 | NorStar Meridian M7310 Phone
My safe to remove icon has dissappeared how can re install it please
Which operating system ?????????
The system tray in Windows XP is the right side of the small blue bar at the bottom of the screen that houses the clock and a few other small icons. You can add icons to the system tray for ease of access, including the "Safely Remove Hardware" icon, which allows you to easily remove hardware from your computer.
Turn on the Windows XP computer and right-click the taskbar. Select "Properties" from the menu that appears. Check "Hide Inactive Icons", then select "Customize" A new window appears with all of the icons currently on the system tray, along with icons also for some programs that don't appear on the tray. Click next to the icon "Safely Remove Hardware," then check the box "Always Show". Click "Apply". Safely Remove Hardware Icon?
http://www.pulpfusion1.com/demotech/e_article000253202.cfm
Mar 13, 2013 | Compaq Computers & Internet
I have downloaded the expat sheild but icon does not appear in tray
The steps are a little different depending on which operating system that you are using. If you select the system tray or right-click it, you should get an option to 'Customize' system notification icons. You can then choose the options to hide or show various icons in the system tray.
Aug 08, 2012 | AnchorFree Expat Shield
Volume icon keeps disappearing from system tray
Volume Control - The volume icon does not appear in the notification area (system tray)
Go to Start/Control Panel/Sounds and Audio Devices.
On the Volume Tab under Device Volume, put a check in the box that reads: Place volume icon in the taskbar.(Classic View)
If that has been tried:
Place your XP CD in then go to Start/Run and type in:
EXPAND -R X:\I386\powrprof.dl_ C:\Windows\System32 (X- is your CD location)
Once done: Go to Start/Run and type in: regsvr32 stobject.dll
or
How to fix system tray icons missing in vista and xp
For those who like to do it manually, open the command prompt and type the following two commands one by one:
From the command prompt, type
"taskkill /f /im explorer.exe"
"explorer.exe"
Hope it helps.
Feb 13, 2011 | Microsoft Windows XP Professional
Winows icon pops up in tray has d/load ready to
Click on Tools on top right of your computer. Check your pop up blocker. You can disable it. It could be that your system is blocking the download. Usually you get a small mesage on the top of the screen asking permission to allow the pop up. Click temporarily allow pop up, then click your download again.
Mar 13, 2010 | Computers & Internet
Icon doesnt appear in systems tray after driver upgrade
Not sure what icon you are refering to but right click toolbar and click properties then select customize locate the icon you want and change it to always show this should do the trick.
Dec 29, 2009 | ASUS Eee PC 1000H Laptop
WD440 conditioner inlet /outlet appears blocked
the most common cause of this problem is a faulty design of the detergent tray, the conditioner works on a syphon system after you feel it up a little bit water is added to it to make the syphon action, either the little wholes above the soap tray are blocked or the soap tray may need cleaning
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
Disappearing icon
i have the same problem but its not with an icon
Nov 30, 2007 | iRiver H10 MP3 Player
Toshiba Satellite 105A speakers/volume
Task tray menu usage You can turn on and off the features by right-clicking on the TOSHIBA Virtual Sound's task tray icon. You can also select a listening mode with this menu.
Task tray icon menu (Off)
Task tray icon menu (On)
Listening environment menu
Task tray appearance The task tray icon will blink when an audio filter is running. If you move a mouse cursor over the icon a pop-up message appear, then it will show a state of the audio filter.
The message which will appear when the SRS WOW HD is available
The message which will appear when the SRS TruSurround XT is available
The message which will appear when the SRS Circle Surround Xtract is available
Oct 30, 2007 | Toshiba Satellite A105 Notebook
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
