I have an Empire vented gas heater and the fan will no longer shut off. Everything else works and cycles on and off correctly. What could be the cause?
    Novelist:
  • 128 Answers
Sounds like the lower limit switch is shot. It is a small quarter sized sensor in the chamber. It senses when the chamber is cool enough to shut off. They are really cheap. there are two and you should replace both the upper and lower limit switch.
good luck,
James.
PLEASE VOTE $ THUMBS!!!
Posted on Apr 26, 2010
Need gas valve for Empire 7088-2 (Nat Gas) heater
Get on computer and type in surplus gas heater valves,or used,or gas valves for --name and # of valve,i can't find the name but there's a Canadian co.that almost has everything gas..years ago they bought up a lot of American companies stock when going out of business of changing product types,there's got to be other companies that have done the same,,ask the wikipedia of out of business gas companies,who bought them out or there parts,someone has them,or a universal valve.
Nov 22, 2012 | Empire Heating & Cooling
I've got a 23 yr old 30DV3 whose pilot light works, and the thermostat & heating element seem to work, but not well. With the thermostat set at full hot, it just barely throws out any heat at all. ...
As I'm sure you already know, Empire Comforts Systems, no longer makes that model heater and hasn't for some years, now. I mentioned that, because if your unit needs parts, they may be almost impossible to get. In any event, there are a several things that may be causing the problem.
  • Low Gas Pressure - Burner is not receiving enough gas. Check for obstructions and have gas pressure at the unit checked.
  • Clogged burner or air intake (venturi valve) is partially clogged. Clean burner ports and venturi valve.
  • Gas line Shut Off Valve at heater not fully open. Check Gas line Shut Off Valve.
At 23 years old, you've gotten your money's worth out of this unit and it may be time to replace it. Empire makes several Direct Vent Wall Furnaces that are rated as High Efficiency Furnaces. In the long run, the money saved in fuel cost, would be worth installing a new one.
Hope this helps you solve the problem.
Apr 11, 2011 | Empire Direct Vent Wall Furnace;...
Furnace lights right up, but will not shut off with on-off switch or thermastat switch? checked out the thermastat switch and that works fine.
Disconnect the thermostat wires from the gas valve, if unit still runs; you have a short in the gas valve and it needs to be replaced.
Feb 22, 2011 | Empire DV-215 Direct Vent Natural Gas...
I have a DV-55 direct vent... Blower kicks on for about 30 sec after it lights then goes of and continues to cycle this way then finally stays on
That is normal...especially if the air is pretty cool when it starts... the air cools the heat exchanger too much and it cycles till everything gets warm... nothing to worry about.. :-)
heatman101
Jan 15, 2011 | Empire Direct Vent Wall Furnace;...
Piolite light keeps going out after unit turns on and reaches temperature set on thermostat.
Check gas pressures standing and working make sure pilot burns correctly and thermocouple is in good order
Dec 13, 2010 | Empire DV-215 Direct Vent Natural Gas...
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Natural gas heater
The burners are shot. The heavy metal tubes with the holes that the burner flame comes out of, has burnt through. Instead of little rows of holes, there is at least one large hole in it. Unless someone has changed the gas>air mixture, you need new burners.
Mar 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
