Water does not exit the washing machine after the cycle ends.
  • 77 Answers
The washer has a clogged drain hose or pump clear the blockage and test
Posted on Apr 26, 2010
My creda simplicty washing machine W200FW) is not finishing programs - it spins and fills but doesn't end - on a rinse cycle it just keeps spinning with water in, on a spin cycle it will drain but on
This is sometimes caused by water not exiting during or at the end of the wash. I have also encountered door lock issue for the same reason.
Jan 21, 2015 | Creda Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Program ends before full cycle leaving clothes in loads of soapy water, happened twice after once I had pushed end button while red with door lock in red
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the inlet valve water pressure is low then the program might take more time and so result in a error. so check inlet valve flow. Also the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally check the drain pump, if choked the drain cycle will extend and result in error.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Hotpoint First Edition WMA22 Front Load...
The washing cycles both (pre-wash and main wash) can't work through to the end. when the water has been filled, the four indicating lights flash together and sounding like tide with rhythm. when...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect since the cycle when advanced seems to go through well.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Aug 27, 2011 | Dishwashers
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Dishwasher is draining during the wash cycle, but leaves water in the bottom at the end of the wash. What could be the problem?
Hello Ellsaesser,
Dishwashers typically leave water in the drain system exitting the pan but not a lot of water. If yours does then make sure you clean the drain screen ( normally located in or around the drain tube exitting the pan of the dishwasher..) If after cleaning that and after a normal wash cycle you continue to have significant volumes of water in the pan, the pump, lines leading to and from that pump may be restricting flow or damaged.. Those are a few of the normal culprets for why there is a lot of water in the pan of dishwashers after a cycle.. Hope that helps you identify the problem and resolve it,..,
Regards
Nov 29, 2009 | Frigidaire Dishwashers
At end of wash cycle, water won't pump out of washing machine
You need to try to put your clothes in the scale to messure the right amount of clothing you will be washing at the time.
Oct 28, 2009 | Kenmore Washing Machines
Water remains under rubber seal. Water too high in bleach dispen.
Did you try taking the dispenser tray apart and cleaning it? The exit ports tend to clog over time. Best thing I have found is to remove the tray at the end of wash day, rinse it out, dry it and put it only partially in the machine, thereby allowing air circulation. Some water will always remain at the end of the wash cycle...inherent in the design.
As for the gasket, you'll have to wipe it down at the end of wash day and leave the door open to dry everything out. I leave mine open all the time.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine not working
Take out your exit hose from behind the machine, try to drain at floor level. Be prepared for a lot of water. Then switch on the machine and press "end of cycle"; try the door after a lapse of 2 minutes. Ref to manual. Not good to 'sir' here, we are at your service! Free!!
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Jan 21, 2008 | Washing Machines
Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Washing Machines Experts
