Question about Toshiba Estudio 200L Copier
Transmission only goes on drive, no reverse - Toshiba Estudio 200L Copier
  • Toshiba Expert
  • 1,326 Answers
That is because it is not designed to....
Posted on Apr 26, 2010
Cars running but wont go into gear,reverse or forward
Transmission seals worn need to have transmission rebuilt
Feb 01, 2017 | Cars & Trucks
WHILE DRIVING
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
Ever notice that while driving that the car hesitates or refuses to go into gear? ... For automatic transmissions, you might notice that when shifting into drive or park ....Neutral and park gears no problem, but drive, 1st, 2nd and reverse engages ...
Trans Goes Into Neutral While Driving - Transmission ...
www.transmissionrepaircostguide.com/topic/trans-goes-into-neutral/
Jun 5, 2015 - When I put it in drive, and begin to drive away the transmission will put itself in neutral. When I slow back down, it will go back into gear.
Jan 13, 2016 | Cars & Trucks
My car goes into reverse but won't go forward. What's the problem?
A similar type of thinking goes into diagnosing car trouble. ... response issue, but after shifting into gear the engine's RPMs will surge, but the car won't move ..... Can anyone please explain why my car cant go in reverse but can drive forward
My car will not go in reverse but will drive forward. What could ...
https://answers.yahoo.com/question/index?qid...
Dec 26, 2007 - My car will not go in reverse but will drive forward. ... I tried putting it in neutral and pushing it backwards, but something catches and it won't budge. ... Either way, it's likely that the transaxle is going to require removal and ... the hood and movethe linkage by hand, then it would shift into gear ok for awhile. Why won't my truck go forward, it only goes in reverse? ' Yahoo ...
Feb 23, 2014
My car won't go into reverse, still okay to drive a 2 hour drive ...
Jan 12, 2011
My car won't go in reverse but it will go forward with no problem ...
Feb 6, 2010
My car will drive forward, but not in reverse... Could this be a ...
Sep 11, 2007
More results from answers.yahoo.com
Dec 16, 2015 | Cars & Trucks
2001 Audi A4 Quattro, Reverse slips
Perhaps it is in severe pain, because you failed to identify it it by make and model!
May 15, 2017 | Cars & Trucks
Servo or band worn out, o.ring gone hard or clutch pack burnt out.
May 14, 2017 | Cars & Trucks
2001 ford f150 goes in reverse but not in drive
Has the transmission control module been tested for fault codes? If none are present to explain this loss of drive then you will need to remove the transmission and repair it or replace it with a rebuilt unit.
Dec 23, 2011 | Cars & Trucks
1989 ford probe automatic suddenly refuses to engage into reverse.
First thing I would suggest is, you check the transmission fluid level in your car. If your fluid level is adequate, then you may need to have your transmission bands adjusted or gears and/or clutches within your transmission replaced.
After reading your question again, I am unsure if you shifter will not engage reverse or the transmission will not go into reverse. Nevertheless, if the transmission will not go into reverse, even after the car warms up, then your transmission may require a serious overhaul. Try driving your vehicle for several miles and see if it goes into reverse after warming up.
Jan 04, 2011 | Ford Probe Cars & Trucks
I have a code po705 my car goes reverse neutral
p0705 is the transmission range sensor which tells the ECM what gear the transmission is in neutral/reverse. Which was probably happened when you lost Drive gear
Jun 02, 2010 | 1999 Ford Windstar
Wont go forward but goes in reverse
internal transmission problem. The forward drive clutch has failed. Sorry for the bad news.
Jan 15, 2009 | 1995 Mitsubishi Galant
When i put my car in reverse it won't move but will drive forward perfect and is full of transmission fluid
Assuming this is an automatic transmission, odds are you have lost a band in your transmission, this will require a rebuild,  you may also notice it will fail to shift into high gear as well?
Oct 29, 2008 | 1984 Oldsmobile Delta 88
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
