Question about Dryers
No heat in dryer, and when on timed drying it will not stop. thought maybe ignitor, but could not find it.
  • 45 Answers
Heating element out.
Posted on Apr 28, 2010
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
Our dryer is about two years old. It is heating up, but only to a warm temperature. Clothes are not really drying and dryer is not hot even when on high temperature. Any thoughts?
If you have already cleaned the lint screen, have you checked the venting system? It is the 4" flexible hose that usually connects in the back of the dryer and leads all the way outdoors. Many times the vent is stopped up causing the dryer to overheat and run longer, maybe not even drying the clothes.
Apr 15, 2011 | Dryers
Maytag neptune gas dryer dryer will run but the igniter will only ignite part of the time, thought we had a bad igniter put in a new one, it lit up right away dryed one load completely dry, put in the next...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Maytag Dryers
The dryer won't dry. I was using dryer sheets and the service tech said don't do that. So I cleaned off the sensor with mild soap. I also replaced the exhaust with flexible metal vs the foil coil type I...
heatman101
Aug 12, 2010 | LG DLG2525S Electric Dryer
Our dryer is not drying! I can see the reflection on the floor underneath the dryer of the heater--it stays on maybe 10 seconds then off then on again in about 10 min. What are your thoughts!
heatman101
Aug 09, 2010 | Kenmore 400 6943 Dryer
Does not heat, automatic timer when out first
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 17, 2010 | Kenmore Dryers
Dryer not drying
heatman101
Jun 07, 2010 | Frigidaire GLGR642A Gas Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Does not dry the clothes.
On the blower housing in the rear is a duct fuse. If the dryer gets stopped up that fuse will blow and kill the gas assembly so I always check that first. Then If that is kosher I check the flame sensor for continuity. if it is open the ignitor and coils won't work. if it turns out to have continuity I next will check the ignitor for continuity. If it is open then nothing can happen right? If the dryer runs and the ignitor glows, shuts down and heats for a short time and then quits then that is the operator coils. mainly the one with 2 wires comes on and stays on most of the time the dryer is calling for heat. the coils come in a pair for $20. On this page I am going to post a better explanation is given with pictures. above the page is a few more links that are helpful. More gas dryer enlightenment
Apr 12, 2009 | Whirlpool LER4634J Electric Dryer
Rheem Criterion Ignitor Issue?
Maybe some trash or water got into the hose from the draft inducer to the proving switch It happens this time of year.
Mar 27, 2009 | Heating & Cooling
Dryers Logo
29 people viewed this question
Top Dryers Experts
