Question about Flotec FP217810 Submersible Well Pump Control Box
Want to switch one one of the 230 wires instead of two
I want to have 110 sent to my well pit. and switch the other one with my pressure switch.
    Problem Solver:
  • 19 Answers
Electrical code requires both hots to be switched on a 230V supply, you can switch one hot and the pump will turn on and off but there will always be an existing electrocution hazard, not a good thing.
Posted on May 18, 2010
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
Replace contacts in ac rheem 060jaz split system were is reset switch
Get wiring schematic check wiring and the restet is turning breaker on and off to unit. Furnace included. Start checking for 24v . To contractor and through pressure switches. 208-230 volts in unit. Beaware
Sep 06, 2013 | Heating & Cooling
110 volt
see side of motor for schematic take off back either turn knob to 110 volts or you have to switch the brown wire to a different lug and the white wire to lug #2 then the black or colored wire goes to #1 and white goes to #2 green to ground
Jul 25, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
I have motor dayton model 9ncg4 now the wire is110 conected i need to conected 220 i need the diagram
I reversed start winding to reverse motor now it runs the right direction but it keeps starting instead of running smooth
Sep 27, 2012 | Dayton Wire Wheels Motor 2 HP 3450 230 V...
I got a used Velodyne SC1250 Amplifier from a friend in the states. Can I switch the power supply from 110 V to 230 V? A pretransformer from 230 to 110 V is to big and not a wishable solution. Are...
If its a transformer based Amplifier you can rewind the primary winding for 230Volt. But it has to be done by a transformer specialist.
All one has to do is unwind the primary on a winding machine and make a note of the number of turnings in the coil. Then wind back twice the number of turns using half the thickness of the wire that was used for 110v.
Eg: if the there were 1000 turns of 20 swg wire in the 110 circuit when you rewind you have to use 40swg wire and wind 2000 turns on the bobin.
Jun 29, 2011 | Velodyne SC1250 Amplifier
The compressor is 3HP 230 v motor. In the pressure switch it is wired white and black from motor and green to ground. Is the white and black wire 115 volt each or it the white wire common and black wire...
If the motor is 230 v then it should have three wires, black, red, and green, however if the motor is convertible from 120 to 230v then the wire from the motor may be black, white, and green. Check the motors label to see if it has different wiring configurations. If the motor is 230 v only then the white wire would be the other side of the 230 v circuit, and the pressure switch should break both sides. Neutral is not used. Note that some people would use a single pole pressure switch, although this will work it is not recommended.
May 07, 2011 | Ingersoll Rand Single Stage Electric...
I have a petrol generator, it puts out 110 and 230 the switch that changes over is a on/on switch when it was running my mate switched it over to 110 from 230 and the was a flash now it does not put out...
You probably will need to replace the switch if it flashed over. I would disconnect it and document the exact connections before as there are usually a bunch of wires to the switch. Test the switch with an ohmmeter.
The flashover MAY have discharged the magnetic field of the rotor and you may have to "flash the field" to restore it. Google "flashing field" as there are a lot of methods.
Worst case is if the unit is a brushless generator and the flash over in the switch shorted the rotating diodes on the rotor. That will require servicing of the generator part of the unit to replace the diode modules.
May 03, 2010 | Coleman Powermate Powermate 5000W...
No spark
there are 2 wires that go to the kill switch. bare them both and put a jumper between the 2 to insure insure its not a switch falure. if you get spark, get a new switch or continue with the jumper. be sure to keep the bare wires from touching metal or youll just ground it out again and it wont start
Feb 11, 2010 | Pit SSR 110CC Pro Beginner Bike
POWER SOURCE 110 VERS 230 VT
some times they provide switch for 110/230 at the back side of monitor. but if you do not have that you can purchase converter which converts 110 to 230 volts ac.
Sep 04, 2007 | LG Studioworks 700S 17" CRT Monitor
Flotec FP217810 Submersible Well Pump Control Box Logo
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
