Question about Toshiba Satellite A215-S4747 Notebook
How do I enter Crisis Recovery Mode on an A215-S7444 with Phoenix BIOS?
  • 509 Answers
SOURCE: activating crisis mode for toshiba satellite a215-s7422
If you mean safe mode, as soon as you turn on the computer start pressing the F8 button about once a second. That should bring you to the safe mode option.
Posted on Jan 04, 2010
  • 83 Answers
SOURCE: How to reset Toshiba A215 S7444 bios password?
Contact Toshiba Support, If you are the Original or Registered owner of that system, they can help u. They have the "Master Password"
Posted on Apr 14, 2010
melaiii
  • 35 Answers
SOURCE: Phoenix bios setup utility is requesting a password
Actually, if you do not know the password it is best not to guess because 3 wrong guesses would result to losing the data on your hard drive forever.
the simplest way to remove a bios setup utility password is by removing the cmos battery. computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
1. open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. please refer to the picture below. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
2. Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
3. Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
linswad
  • 258 Answers
SOURCE: I have a previously owned Toshiba A215 S7444
You can either find the CMOS backup battery and take it out for a while to let the memory discharge, or look online to find a program which will crack the Phoenix password (these do exist, I had to use them when I was in business fixing computers).
Posted on Apr 17, 2010
chiplevel
  • 656 Answers
SOURCE: My CMOS shows bad cheksum
remove the battery and replace it with a new one the checksome error is due to the battrrey
Posted on Nov 14, 2010
Samsung Sens X06 bios fail
see this steps and proceed .God bless you
    • 1 Download a crisis recovery program designed specifically to restore damaged or otherwise non-functioning copies of Phoenix BIOS. Read the instructions for using the recovery program to make sure that no specific changes or configurations need to be done to it before it is used.
    • 2 Place the Phoenix BIOS recovery program and its files onto a blank disc or a USB drive according to the program's instructions (this usually simply consists of extracting the files from an archive.) Once the program and its files are in place, insert the disc into the computer's drive or plug the USB drive into an available USB port.
    • 3 Hold down both the Windows key and the "B" key on your keyboard and press the power button on the computer. (On some laptop computers, you will need to press the "Fn-B" keys instead.) Wait for the disc drive light or the USB drive access light to start flickering to show that the computer is accessing the Phoenix BIOS recovery program, and then release the keys.
    • 4 Wait patiently while the Phoenix BIOS recovery program overwrites the damaged sections of the motherboard's current BIOS installation. Depending on the computer and the recovery program used, the computer may or may not reboot once BIOS recovery is complete. If the computer does not reboot on its own, wait at least 10 minutes before manually restarting the computer to make sure that you do not interrupt BIOS recovery. Eject the disc or remove the USB drive before rebooting to prevent accidentally reloading the recovery program.
    • 5 Reboot the computer and watch to make sure the Phoenix BIOS screen appears as normal. Once the BIOS loads properly, your operating system should launch as normal.
Oct 18, 2012 | Computers & Internet
I have a toshiba sattelite a215-s7444 and lost the adminastrator password to get on my laptop is there any way to bypass my old password I tried to burn a usb reset key but it wont work thanks
If it's the BIOS password then no, only a Toshiba dealer can reset it. If it's a Windows password then use this
http://pogostick.net/~pnh/ntpasswd/
Aug 18, 2011 | Toshiba Satellite A215-S7444 Notebook
WHEN I TURN ON MY LABTOP WHAT I SEE IS ENTER PASSWORD (BIOS).SATELITE A215-S7444
if you forgot password remove mainboard battery for 5 min will clear all passwords
Feb 02, 2011 | Toshiba Satellite A215-S7462 Laptop
Toshiba a215 s7444 high pitched noise
If the high pitch noise is coming from the bottom edge of the LCD screen, then the noise could be coming from the inverter.
Replacement inverters are available from :-
www.lcdparts.net
Nov 03, 2010 | Toshiba Satellite A215-S7444 Notebook
I have a previously owned Toshiba A215 S7444 Satellite Laptop, when booting up I get a black screen and it asks for the Phoenix Bios Password. The previous owner does not know the password and it is NOT...
Apr 17, 2010 | Toshiba Satellite A215-S7444 Notebook
Apr 13, 2010 | Toshiba Satellite A215-S7444 Notebook
Activating crisis mode for toshiba satellite a215-s7422
Jan 04, 2010 | Toshiba Satellite A215-S4747 Notebook
Toshiba Satellite A215-S4747 Notebook Logo
420 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
