Question about Philips Televison & Video
I am trying to use my 19PFL3403D AS A MONITOR FROM MY pc. i HAVE THE CORRECT ASPECT RATIO, have made sure the 60 Hrz is being used and have no problem with the safe mode. But when I go to standard computer start up the Windows display shows on the Phipips, but as soon as the HD part starts the TV comes back with no video input. How do I correct this? Pat
  • pbird49 Apr 26, 2010
    My control panel has no Appearance and Themes section.
    I do not know where to get the driver.
    My system is connected using the 15 pin cable to the TV.
    I am using Windows XP.
    President:
  • 1,768 Answers
The standard monitors resolution is fixed at 1280X760 beyond the monitors capabilities.
You will require a HD monitor with resolution at 1920X1080 = 1080P
1366X768 + 720P
Posted on Apr 26, 2010
  • Philips Master
  • 12,061 Answers
OK, you simply have to setup the Video setup correctly, you MUST have the latest drivers, for the PC, then you need to setup as an Extended Desktop, also the initial screen resolution, need to be set so the TV can display it. These settings must be all done before you can use the PC & TV, as a monitor, As related you MUST get the latest Driver, for your Video card. If you have an ATI or an NVIDIA, card, they all have "Control Centers" that allow one to setup the multiple desktops, all in the one place... you didn't say, what your "Connection" to the "TV" was, Composite, Component, or HDMI. IF Using HDMI, again you MUST download and install the latest, HDMI driver, which is usually a separate download, & install.
http://support.microsoft.com/kb/307873
The above link, givers you a step by step how To?
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
Says that it is out of range 75hrz
Your graphix card are trying to output a 75hrz picture, while your monitor probably does not support more than 60 etc. Most LCD's today only support 60, while earlier CRT's often supported 75 etc.
Have you changed your monitor lately? If so, change it back, go to where you change monitor resolution. Then you will probably have to choose advanced settings, and monitor or something like that to find where to lower the hrz. Need to know your Os to say exactly how.
Feb 27, 2011 | Computers & Internet
People look short and fat
You are trying to display standard definition TV 4:3 ASPECT RATIO to fill up the 16:9 screen and that is what you will get. You need to use the 'APSECT', 'P.MODE', or 'WIDE' button to set correct aspect ration to match the video source aspect ratio. Please see you owner manual for more details.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 07, 2010 | Vizio Televison & Video
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
My Sister has a dell monitor and a emachines tower, She cant get the monitor to turn on. is it compatible? Or is there something else she should try cause she has it hooked up right.
They are compatible, make sure your connectors are right... If the emachine is using a graphics card, make sure it is hooked up to the greaphics card not the motherboard but if you do have it hooked up to the graphics card, then try the motherboard's video output.
Feb 23, 2010 | E-Machines eMachines Monitor E15T4
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
We recently installed a 23'/HF237 monitor. Everything looks great except the picture on the screen is stretch horizonally, causing distortion. I publish a sports magazine and I need the screen to show an...
You need to set your PC display adaptor to correct resolution maybe 1440 >< 900.You need to select resolution which is correct for this widescreen monitor (16: 10) Aspect ratio as opposed to 4 :3 CRT monitor you must have been using previously.
Samir
Jul 09, 2009 | Computers & Internet
22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Mar 17, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Televison & Video Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
