Question about Whirlpool Duet GHW9150P Front Load Washer
Lost power during cycle. now I get F11 error code and it wont drain/spin
    Scholar:
  • 126 Answers
1. Unplug washer or disconnect power. then plug back in after 1 minute. See if that works. there really is no 100% way to diagnose. sounds like the ctrol board in the top back needs to be replaced.
if you are mech. inclined you can follow this procedure.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
Posted on Apr 25, 2010
    Genius:
  • 1,400 Answers
Hello
Un plug washer for a min.Plug back in,Restart wash cycle from the begining.
  • mpcheesman1
    mpcheesman1 Apr 26, 2010
    Im sorry,try hitting pause and cancel twice also.
Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
Trust this helps, best regards Alan
Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
Feb 12, 2015 | Kenmore Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
The F11 error can be difficult to resolve even for us technician's.
The F11 error occurs when the central control and motor control don't talk to each other.
If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The water wont drain and has a code in think is'ts Cu I think its the control panel any suggestion. We accidently shut the water off during s cycle to fix a sink, since then it wont work,
Could the error code displayed be UC for a unballance detected during the start of a spin cycle?
If you remove the wash load and place the washer in a Spin Only cycle it should complete the cycle and drain the machine. You can turn on the drain pump in Service Mode also but this is the quickest way for now.
Please confirm the error code and the machine model number. If you want help to DIY the fix I can help. you but you need to move to another forum. You can't get the Service Manual from this forum and I can't find my post most of the time. This forum is not really well thought out for DIY owners.
See this post 5th post down I the issue and fix if you are taking unballance errors in Spin Cycle
You can get the Service Manual from this location........Rich
Feb 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Whirlpool GHW9100L was tripping out with a F11 error during the rinse/spin cycle as the unit was ramping up to spin speed with a small load in the wash bin. I reset the unit several times after...
Hi.
In your case the problem is more likely a worn connector or a defective board.
F11 is communication error between CCU (main control unit) and MCU (motor control unit - additional control module connected to motor and to CCU, located in a sealed box inside the washer).
This usually means that either CCU or MCU is defective. In some case the connectors or the wiring harness connecting the two modules is the problem.
The tech sheet says:
F11:Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Solution:
* Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
The wiring harness is tested using a multimeter to ensure that there is continuity between the MCU and CCU connectors. If a single wire is good it will read zero Ohms (closed) from contact to contact.
Motor is tested reading Ohms, it must be read about 6 Ohms on three different pairs of contacts.
Drive system in motor is checked observing if any of the parts are broken.
MCU and CCU are tested reading volts during operation and testing at component level. The testing must be done by a tech. Check CCU to see if there is any sign of failure (eg burnt spots).
Most of the time the problem is CCU. Trick to repair it include testing and eventually reheating the solder joint of the two on-board relays, cleaning connector contacts with circuit cleaner solution. This in case that the problem is CCU.
Disconnect the unit from power for five minutes as first test. This will reset CCU.
Dec 15, 2010 | Whirlpool GHW9100L Front Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Hotpoint Aqualtis Error code F11
please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
Jun 27, 2008 | Washing Machines
Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
Dec 10, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
